MasterFan Pro 120 Air Pressure image number 0
MasterFan Pro 120 Air Pressure image number 1
MasterFan Pro 120 Air Pressure image number 2
MasterFan Pro 120 Air Pressure image number 3
Select Your Silence
  • Accessory 4x Tap Screw
  • Cooler Type Case Fan
  • Warranty 5 years
  • Fan Power Consumption 0.84W - S Mode (Silent)
  • LED Lighting Non-LED
  • Fan Size 120
  • LED Non-LED
  • Fan Life Expectancy 490,000 Hours
  • Fan Power Consumption 1.32W - Q Mode (Quiet)
  • Fan Power Consumption 2.16W - P Mode (Performance)
  • Series MasterFan Pro
  • Fan Weight 158g / 0.35lb
  • Fan Rated Current 0.07A - S Mode (Silent)
  • Fan Rated Current 0.11A - Q Mode (Quiet)
  • Fan Rated Current 0.18A - P Mode (Performance)
  • EAN code 4719512052570
  • UPC code 884102028687
  • Fan Noise Level 6-20 dBA - S Mode (Silent)
  • Fan Noise Level 6-30 dBA - Q Mode (Quiet)
  • Fan Noise Level 6-36 dBA - P Mode (Performance)
  • Product Number MFY-P2NN-15NMK-R1
  • Fan Speed 650-1550 RPM ± 10% - S Mode (Silent)
  • Fan Speed 650-2250 RPM ± 10% - Q Mode (Quiet)
  • Fan Air Pressure 1.45 mmH2O ± 10% - S Mode (Silent)
  • Fan Air Pressure 3.14 mmH2O ± 10% - Q Mode (Quiet)
  • Fan Speed 650-2750 RPM ± 10% - P Mode (Performance)
  • Fan Air Pressure 4.6 mmH2O ± 10% - P Mode (Performance)
  • Fan Airflow 35 CFM ± 10% - S Mode (Silent)
  • Fan Airflow 53.5 CFM ± 10% - Q Mode (Quiet)
  • Fan Airflow 62.1 CFM ± 10% - P Mode (Performance)
