Select Your Silence
MasterFan Pro 120 Air Flow
Fan Rated Voltage12 VDC
Accessory4x Tap Screw
Fan Power Connector4-Pin (PWM)
Cooler TypeCase Fan
Warranty5 years
Fan Power Consumption0.84W - S Mode (Silent)
LED LightingNon-LED
Fan Size120
LEDNon-LED
Fan Life Expectancy490,000 Hours
Fan Power Consumption1.44W - Q Mode (Quiet)
Fan Power Consumption2.16W - P Mode (Performance)
SeriesMasterFan Pro
Fan Weight147g
Fan Rated Current0.07A - S Mode (Silent)
Fan Rated Current0.18A - P Mode (Performance)
Fan Rated Current0.12A - Q Mode (Quiet)
EAN code4719512052563
UPC code884102028670
Fan Noise Level6-20 dBA - S Mode (Silent)
Fan Noise Level6-30 dBA - Q Mode (Quiet)
Fan Noise Level6-36 dBA - P Mode (Performance)
Product NumberMFY-F2NN-11NMK-R1
Fan Speed650-1100 RPM ± 10% - S Mode (Silent)
Fan Speed650-1550 RPM ± 10% - Q Mode (Quiet)
Fan Air Pressure0.88 mmH2O ± 10% - S Mode (Silent)
Fan Air Pressure1.74 mmH2O ± 10% - Q Mode (Quiet)
Fan Speed650-1900 RPM ± 10% - P Mode (Performance)
Fan Air Pressure2.61 mmH2O ± 10% - P Mode (Performance)
Fan Airflow48.8 CFM ± 10% - S Mode (Silent)
Fan Airflow72.4 CFM ± 10% - Q Mode (Quiet)
Fan Airflow84.5 CFM ± 10% - P Mode (Performance)
