MasterFan MF200R RGB image number 0
MasterFan MF200R RGB image number 1
MasterFan MF200R RGB image number 2
MasterFan MF200R RGB image number 3
MasterFan MF200R RGB image number 4
MasterFan MF200R RGB image number 5
MasterFan MF200R RGB image number 6
MasterFan MF200R RGB image number 7
BIG, BRIGHT, & BOLD
The MasterFan MF200R RGB, a new member of the MasterFan family, provides a specific air cooling solution ideal for chassis in-take fans.
  • Fan Power Connector 3-Pin
  • Fan L-10 Life 25,000 Hours
  • Fan Profiles RGB
  • LED Lighting RGB
  • Cooler Type Case Fan
  • Fan Size 200
  • Fan MTTF 175,000 Hours
  • Number of LEDs 8pcs
  • Fan Safety Current 0.3A
  • Series MasterFan
  • Fan Air Pressure 0.88 mmH2O ± 10%
  • Fan Dimensions (L x W x H) 200 x 200 x 25 mm / 7.9 x 7.9 x 1 inch
  • Fan Speed 800 RPM ± 150
  • Fan Weight 254g
  • Fan Airflow 90 CFM ± 10%
  • Fan Noise Level 28 dBA
  • Product Number R4-200R-08FC-R1
