MasterFan MF140 Halo White Edition image number 0
MasterFan MF140 Halo White Edition image number 1
MasterFan MF140 Halo White Edition image number 2
MasterFan MF140 Halo White Edition image number 3
MasterFan MF140 Halo White Edition image number 4
Halo of Light
Cooler Master is introducing a new addition to the MasterFan Halo Series, the MF140 Halo White Edition.
  • RGB Rated Voltage 5 VDC
  • LED Lighting ARGB
  • RGB Connector 3-Pin ARGB
  • Number of LEDs 24pcs
  • Exterior Color White
  • Fan MTTF 160,000 Hours
  • Cooler Type Case Fan
  • Fan Bearing Type LDB
  • Fan Size 140
  • Fan Noise Level 6 - 30 dBA
  • Fan Safety Current 0.4A
  • RGB Rated Current 0.55A (0.8A Max)
  • Profile Non-LED
  • Fan Power Consumption 1.8W
  • Fan Rated Current 0.15A
  • Fan Dimensions (L x W x H) 140 x 140 x 25 mm / 5.5 x 5.5 x 1 inch
  • Series MasterFan
  • Fan Weight 215g / 0.47 lbs
  • Fan Air Pressure 1.17 mmH₂O ± 10%
  • Fan Speed 650-1500 RPM (PWM) ± 10%
  • Fan Airflow 55 CFM ± 10%
  • Product Number MFL-B4DW-15NPA-R1
