MasterFan MF120 S3 image number 0
MasterFan MF120 S3 image number 1
MasterFan MF120 S3 image number 2
MasterFan MF120 S3 image number 3
MasterFan MF120 S3 image number 4
MasterFan MF120 S3
MasterFan MF120 S3
MasterFan MF120 S3
MasterFan MF120 S3
MasterFan MF120 S3
Lighting Up Your Systems
MasterFan MF120 S3
MasterFan MF120 S3 provides a specific air cooling solution ideal for CPU coolers and chassis in-take fans.
  • RGB Rated Voltage 5 VDC
  • LED Lighting ARGB
  • RGB Connector 3-Pin ARGB
  • Number of LEDs 16pcs
  • Fan MTTF 160,000 Hours
  • Fan Bearing Type LDB
  • Cooler Type Case Fan
  • Fan Safety Current 0.37A
  • Fan Size 120
  • RGB Rated Current 0.65A
  • Series MasterFan
  • Fan Power Consumption 2.64W
  • Fan Rated Current 0.22A
  • Fan Weight 156g / 0.34 lbs
  • Fan Speed 650-1800 RPM ± 10%
  • Fan Noise Level 8 - 27 dBA
  • Fan Air Pressure 1.82 mmH2O (Max)
  • Fan Airflow 52 CFM (Max)
  • Product Number MFW-B2DN-18NPA-S3
