MasterFan MF120 Halo 3in1 image number 0
MasterFan MF120 Halo 3in1 image number 1
MasterFan MF120 Halo 3in1 image number 2
Halo Of Light
MasterFan MF120 Halo 3in1, a new series to the MasterFan family, provides a specific air cooling solution ideal for CPU coolers...
  • RGB Rated Voltage 5 VDC
  • RGB Connector 3-Pin
  • LED Lighting ARGB
  • Fan Air Pressure 1.6 mmH2O ± 10%
  • Cooler Type Case Fan
  • Fan MTTF 160,000 Hours
  • Fan Bearing Type LDB
  • Fan Noise Level 6 - 30 dBA
  • Fan Safety Current 0.37A
  • Fan Size 120
  • RGB Rated Current 0.55A
  • Profile Non-LED
  • Series MasterFan
  • Fan Power Consumption 3.0W
  • Fan Rated Current 0.25A
  • Fan Weight 180g x 3
  • Fan Speed 650-1800 RPM ± 10%
  • Fan Airflow 47.2 CFM ± 10%
  • Product Number MFL-B2DN-183PA-R1
