WITH FREEFORM™ MODULAR SYSTEM
MasterCase Pro 5
MasterCase Pro 5
SeriesMasterCase Series
Radiator Support - Rear120mm
Power Supply SupportBottom Mount
Dust FiltersTop
Cooling Support - Top2x 120/140mm (Optional)
Cable Management25mm
RemarkW/ Top Cover
RemarkTop Water Bracket
Dust FiltersFront
Radiator Support - Rear140mm
I/O Panel2x USB 3.0
SizeMid Tower
MaterialsPlastic
LegacyCases
Cooling Support - Rear1x 140mm (Pre-installed)
Dust FiltersBottom
RemarkSide Window
Cooling Support - Front2x 140mm (Pre-installed)
Cooling Support - Front1x 120/140mm (Optional)
Radiator Support - Top280mm
Radiator Support - Front280mm
5.25" Drive Bays2
Drive Bays - 2.5" SSD2 + 5
Radiator Support - Front240mm
3.5" Drive Bays5
Radiator Support - Top240mm
Power Supply SupportATX PS2
MaterialsSECC
Expansion Slots7
Color(s)Dark metallic grey exterior with black interior
Maximum Compatibility - VGA Card Length296mm / 11.7 inch (with 3.5" HDD Cage)
Dimensions (L x W x H)512 x 235 x 548 mm
I/O PanelAudio In & Out (Supports HD Audio)
Maximum Compatibility - VGA Card Length412mm / 16.22 inch (w/o 3.5" HDD cage)
Maximum Compatibility - CPU Cooler Height190mm/7.5 inch
Weight10.7 kg / 23.6 lb
Dimensions (L x W x H)460(L) x 235(W) x 460(H) mm (Body)
Model NumberMCY-005P-KWN00
Confirm your Country
It looks like you're in
