MasterCase Pro 5 image number 0
MasterCase Pro 5 image number 1
MasterCase Pro 5 image number 2
MasterCase Pro 5 image number 3
MasterCase Pro 5 image number 4
MasterCase Pro 5
MasterCase Pro 5
MasterCase Pro 5
MasterCase Pro 5
MasterCase Pro 5
WITH FREEFORM™ MODULAR SYSTEM
MasterCase Pro 5
MasterCase Pro 5
  • Series MasterCase Series
  • Dust Filters Top
  • Cooling Support - Top 2x 120/140mm (Optional)
  • Cable Management 25mm
  • Remark W/ Top Cover
  • Remark Top Water Bracket
  • Dust Filters Front
  • Radiator Support - Rear 140mm
  • I/O Panel 2x USB 3.0
  • Size Mid Tower
  • Materials Plastic
  • Legacy Cases
  • Cooling Support - Rear 1x 140mm (Pre-installed)
  • Dust Filters Bottom
  • Remark Side Window
  • Cooling Support - Front 2x 140mm (Pre-installed)
  • Cooling Support - Front 1x 120/140mm (Optional)
  • Radiator Support - Top 280mm
  • 5.25" Drive Bays 2
  • Drive Bays - 2.5" SSD 2 + 5
  • 3.5" Drive Bays 5
  • Materials SECC
  • Expansion Slots 7
  • Color(s) Dark metallic grey exterior with black interior
  • Maximum Compatibility - VGA Card Length 296mm / 11.7 inch (with 3.5" HDD Cage)
  • Dimensions (L x W x H) 512 x 235 x 548 mm
  • Maximum Compatibility - VGA Card Length 412mm / 16.22 inch (w/o 3.5" HDD cage)
  • Maximum Compatibility - CPU Cooler Height 190mm/7.5 inch
  • Weight 10.7 kg / 23.6 lb
  • Dimensions (L x W x H) 460(L) x 235(W) x 460(H) mm (Body)
  • Model Number MCY-005P-KWN00
