MasterCase Pro 3 image number 0
MasterCase Pro 3 image number 1
MasterCase Pro 3 image number 2
MasterCase Pro 3 image number 3
MasterCase Pro 3 image number 4
MasterCase Pro 3 image number 5
MasterCase Pro 3 image number 6
MasterCase Pro 3 image number 7
MasterCase Pro 3 image number 8
MasterCase Pro 3 image number 9
MasterCase Pro 3 image number 10
MasterCase Pro 3 image number 11
MasterCase Pro 3
MasterCase Pro 3
MasterCase Pro 3
MasterCase Pro 3
MasterCase Pro 3
MasterCase Pro 3
MasterCase Pro 3
MasterCase Pro 3
MasterCase Pro 3
MasterCase Pro 3
MasterCase Pro 3
MasterCase Pro 3
Make of It What You Will
MasterCase Pro 3
  • Series MasterCase Series
  • Materials Steel
  • Pre-installed Fans - Rear 1x 140mm, 1200RPM
  • 5.25" Drive Bays 0
  • Materials Plastic
  • 3.5" Drive Bays 2
  • I/O Panel 2x USB 3.0
  • Radiator Support - Rear 140mm
  • Color(s) Black
  • Legacy Cases
  • Size Mini Tower
  • Power Supply Support ATX PS2 / EPS 12V
  • Radiator Support - Top 280mm
  • Clearance - GFX 258mm/10.16" (w/ 3.5" HDD cage)
  • 2.5" Drive Bays 2+2
  • Expansion Slots 5
  • Pre-installed Fans - Front 1x 140mm (1200RPM)
  • Clearance - CPU Cooler 190mm
  • Clearance - GFX 370mm/14.57" (w/o 3.5" HDD cage)
  • Dimensions (L x W x H) 467 x 235 x 505 mm
  • UPC Code 884102029417
  • EAN Code 4719512053300
  • Model Number MCY-C3P1-KWNN
