MasterCase MC500P image number 0
MasterCase MC500P image number 1
MasterCase MC500P image number 2
MasterCase MC500P image number 3
MasterCase MC500P image number 4
MasterCase MC500P image number 5
MasterCase MC500P image number 6
MasterCase MC500P image number 7
MasterCase MC500P image number 8
MasterCase MC500P image number 9
MasterCase MC500P
MasterCase MC500P
MasterCase MC500P
MasterCase MC500P
MasterCase MC500P
MasterCase MC500P
MasterCase MC500P
MasterCase MC500P
MasterCase MC500P
MasterCase MC500P
REMASTERED. GET MORE, PAY LESS!
MasterCase MC500P
MasterCase MC500P
  • Series MasterCase Series
  • Materials Steel
  • Dust Filters Top
  • Pre-installed Fans - Rear 1x 140mm, 1200RPM
  • I/O Port - USB-Ports 2x USB 2.0
  • I/O Port - Audio In/Out Yes (support HD audio)
  • Extra Features Extra Solid Front Panel
  • I/O Port - USB-Ports 2x USB 3.0
  • Dust Filters Front
  • Pre-installed Fans - Front 2x 140mm, 1200RPM
  • Radiator Support - Rear 140mm
  • Materials Plastic
  • Size Mid Tower
  • Materials Tempered Glass
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Radiator Support - Top 280mm
  • 5.25" Drive Bays 2
  • Motherboard Support E-ATX
  • Motherboard Support ATX
  • Expansion Slots 7
  • Clearance - GFX 296mm (w/ 3.5" HDD cage)
  • Cable Routing - Behind Motherboard Tray 25-35mm
  • 2.5" / 3.5" Drive Bays (Combo) 4
  • EAN Code 4719512065549
  • UPC Code 884102038068
  • Dimensions (L x W x H) 512 x 235 x 548 mm
  • 2.5" / 3.5" Drive Bays (Combo) 8 or 10 (with ODD bay removed)
  • Color(s) Dark metallic grey exterior with black interior
  • Clearance - CPU Cooler 190mm
  • 2.5" Drive Bays 2 (Max.4)
  • Clearance - GFX 412mm (w/o 3.5" HDD cage)
  • Model Number MCM-M500P-KG5N-S00
