MasterCase MC500M image number 0
MasterCase MC500M image number 1
MasterCase MC500M image number 2
MasterCase MC500M image number 3
MasterCase MC500M image number 4
MasterCase MC500M image number 5
MasterCase MC500M image number 6
MasterCase MC500M image number 7
MasterCase MC500M image number 8
MasterCase MC500M image number 9
MasterCase MC500M image number 10
MasterCase MC500M image number 11
MasterCase MC500M
MasterCase MC500M
MasterCase MC500M
MasterCase MC500M
MasterCase MC500M
MasterCase MC500M
MasterCase MC500M
MasterCase MC500M
MasterCase MC500M
MasterCase MC500M
MasterCase MC500M
MasterCase MC500M
Remastered. Get More, Pay Less!
MasterCase MC500M
MasterCase MC500M
  • Series MasterCase Series
  • Materials Steel
  • Dust Filters Top
  • Pre-installed Fans - Rear 1x 140mm, 1200RPM
  • Dust Filters Front
  • Pre-installed Fans - Front 2x 140mm, 1200RPM
  • Radiator Support - Rear 140mm
  • Materials Plastic
  • Size Mid Tower
  • Legacy Cases
  • Materials Tempered Glass
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Radiator Support - Top 280mm
  • 5.25" Drive Bays 2
  • Drive Bays - SSD 1
  • Lighting Support 1x RGB Control Board (Cycle, Static, M/B Modes) to Pre-built LED Partition Plate Two Additional Connections Available
  • Motherboard Support E-ATX
  • Motherboard Support ATX
  • Expansion Slots 7
  • Clearance - GFX 296mm (w/ 3.5" HDD cage)
  • Cable Routing - Behind Motherboard Tray 25-35mm
  • I/O Panel 3x USB 3.0 Type-A
  • 2.5" / 3.5" Drive Bays (Combo) 4
  • 2.5" / 3.5" Drive Bays (Combo) 8 or 10 (with ODD bay removed)
  • I/O Panel 1x USB 3.1 Type-C
  • Color(s) Dark metallic grey exterior with black interior
  • Clearance - CPU Cooler 190mm
  • Dimensions (L x W x H) 528.6 x 235 x 548mm
  • Clearance - GFX 412mm (w/o 3.5" HDD cage)
  • I/O Panel Fan Speed & RGB control buttons
  • 2.5" Drive Bays 1
  • Model Number MCM-M500M-KG5N-S00
