MasterCase MC500 Mid Tower PC Case image number 0
MasterCase MC500 Mid Tower PC Case image number 1
MasterCase MC500 Mid Tower PC Case image number 2
MasterCase MC500 Mid Tower PC Case image number 3
MasterCase MC500 Mid Tower PC Case image number 4
MasterCase MC500 Mid Tower PC Case image number 5
MasterCase MC500 Mid Tower PC Case image number 6
MasterCase MC500 Mid Tower PC Case image number 7
Remastered. Get More, Pay Less!
Cooler Master is breaking new ground in the way cases are designed, made, bought and used. Fundamental to this reimagining is FreeForm™.
  • Series MasterCase Series
  • Materials Steel
  • Dust Filters Top
  • Pre-installed Fans - Rear 1x 140mm, 1200RPM
  • Dust Filters Front
  • Radiator Support - Rear 140mm
  • I/O Panel 2x USB 3.0
  • Materials Plastic
  • Size Mid Tower
  • Materials Tempered Glass
  • Dust Filters Bottom
  • Power Supply Support ATX
  • 5.25" Drive Bays 2
  • Drive Bays - 2.5" SSD 2
  • Motherboard Support E-ATX
  • I/O Panel 2x USB 2.0
  • Motherboard Support ATX
  • Clearance - GFX 296mm (w/ 3.5" HDD cage)
  • Expansion Slots 7
  • Pre-installed Fans - Front 1x 140mm (1200RPM)
  • Cable Routing - Behind Motherboard Tray 25-35mm
  • Dimensions (L x W x H) 512 x 235 x 548 mm
  • Fan Support - Top 2x 120mm
  • 2.5" / 3.5" Drive Bays (Combo) 8 or 10 (with ODD bay removed)
  • Clearance - CPU Cooler 190mm
  • EAN Code 4719512065532
  • UPC Code 884102038051
  • Clearance - GFX 412mm (w/o 3.5" HDD cage)
  • 2.5" Drive Bays 4
  • Model Number MCM-M500-KG5N-S00
