MasterCase Maker 5 image number 0
MasterCase Maker 5 image number 1
MasterCase Maker 5 image number 2
MasterCase Maker 5 image number 3
MasterCase Maker 5 image number 4
MasterCase Maker 5 image number 5
MasterCase Maker 5 image number 6
MasterCase Maker 5 image number 7
MasterCase Maker 5
MasterCase Maker 5
MasterCase Maker 5
MasterCase Maker 5
MasterCase Maker 5
MasterCase Maker 5
MasterCase Maker 5
MasterCase Maker 5
Make of It What You Will
MasterCase Maker 5
The new wave of case technology pioneered by our MasterCase Series crests with the unique FreeFrom Modular System.
  • I/O Panel 1x USB 3.0
  • Lighting Support 4 LED Connections
  • Cooling Support - Front 2x 140x25mm Fan, 1200RPM (Pre-Installed)
  • Cooling Support - Rear 1x 140 x 25mm Fan, 1200 RPM (Pre-installed)
  • Cooling Support - Top 2x 120/140mm (Optional)
  • Cooling Support - Rear 1x 120mm Fan (Optional)
  • Legacy Cases
  • Cooling Support - Front 1x 140x25mm Fan (Optional)
  • Radiator Support - Rear 140mm
  • Size Mid Tower
  • 5.25" Drive Bays 2
  • 3.5" Drive Bays 5
  • I/O Panel 2x USB 2.0
  • Motherboard Support ATX
  • Expansion Slots 7
  • Lighting Support 1x Red LED Strip (Pre-installed)
  • 2.5" Drive Bays 2+5
  • I/O Panel 1x USB 3.0 Type-C
  • Dimensions (L x W x H) 528.6 x 235 x 548 mm / 20.8 x 9.3 x 21.6 inch
  • Maximum Compatibility - VGA Card Length 296mm / 11.7 inch (with 3.5" HDD Cage)
  • Radiator Support - Front 280mm (requires removal of ODD cage)
  • Maximum Compatibility - CPU Cooler Height 190mm / 7.48 inch
  • Radiator Support - Top 280mm (max. 297mm radiator length)
  • Power Supply Support ATX PS2 (maximum length: 200mm)
  • Maximum Compatibility - VGA Card Length 412mm / 16.22 inch (w/o 3.5" HDD cage)
  • Net Weight 12.3 kg / 27.2 lb
