MasterCase H500P Mesh White image number 0
MasterCase H500P Mesh White image number 1
MasterCase H500P Mesh White image number 2
MasterCase H500P Mesh White image number 3
MasterCase H500P Mesh White image number 4
MasterCase H500P Mesh White image number 5
MasterCase H500P Mesh White image number 6
MasterCase H500P Mesh White image number 7
MasterCase H500P Mesh White image number 8
MasterCase H500P Mesh White image number 9
MasterCase H500P Mesh White image number 10
MasterCase H500P Mesh White image number 11
MIND-BLOWING DESIGN
  • Series MasterCase Series
  • Materials - Body Steel
  • Materials - Outlook Steel Mesh
  • Liquid Cooling Support - Front 120mm
  • Liquid Cooling Support - Rear 120mm
  • Liquid Cooling Support - Rear 140mm
  • Legacy Cases
  • Liquid Cooling Support - Front 140mm
  • Liquid Cooling Support - Top 120mm
  • Fan Support - Front 2x 200mm Fan
  • 5.25" Drive Bays 0
  • Materials - Side Panel Steel
  • I/O Panel 2x USB 3.0
  • Size Mid Tower
  • Color(s) White
  • Power Supply Support ATX
  • Materials - Outlook Plastic
  • Liquid Cooling Support - Top 140mm
  • Liquid Cooling Support - Front 240mm
  • Liquid Cooling Support - Front 280mm
  • Liquid Cooling Support - Top 240mm
  • Fan Support - Top 3x 120/140mm
  • Pre-installed Fans - Rear 1x 140 x 25mm Fan, 1200RPM
  • Liquid Cooling Support - Top 280mm
  • Liquid Cooling Support - Front 360mm
  • Expansion Slots 7+2
  • I/O Panel 2x USB 2.0
  • Motherboard Support E-ATX
  • Liquid Cooling Support - Top 360mm (maximum thickness clearance 55mm)
  • Drive Bays - 2.5" SSD 2
  • Motherboard Support ATX
  • Pre-installed Fans - Front 2x 200 x 25mm RGB Fan, 800RPM
  • EAN Code 4719512068526
  • UPC Code 884102041037
  • Dimensions (L x W x H) 544 x 242 x 542mm / 21.4 x 9.5 x 21.3 inch
  • Fan Support - Top 2x 200mm
  • Maximum Compatibility - CPU Cooler Height 190mm / 7.5 inch
  • Clearance - GFX 412mm/16.2"
  • Model Number MCM-H500P-WGNN-S00
