MasterCase H500P ARGB Mid Tower PC Case image number 0
MasterCase H500P ARGB Mid Tower PC Case image number 1
MasterCase H500P ARGB Mid Tower PC Case image number 2
MasterCase H500P ARGB Mid Tower PC Case image number 3
MasterCase H500P ARGB Mid Tower PC Case image number 4
MasterCase H500P ARGB Mid Tower PC Case image number 5
MasterCase H500P ARGB Mid Tower PC Case image number 6
Mind-Blowing Design
Dual 200mm fans take the center-stage in the MasterCase H500P ARGB ATX case. Airflow is provided through mesh ventilation...
  • Materials Steel
  • Dust Filters Top
  • Pre-installed Fans - Rear 1x 140mm, 1200RPM
  • 5.25" Drive Bays N/A
  • Fan Support - Front 2x 200mm
  • Legacy Cases
  • Dust Filters Front
  • Radiator Support - Rear 140mm
  • Materials Plastic
  • Materials Tempered Glass
  • 2.5" Drive Bays 2
  • Dust Filters Bottom
  • Radiator Support - Top 360mm
  • Fan Support - Top 3x 120/140mm
  • Power Supply Support ATX
  • Radiator Support - Top 280mm
  • Expansion Slots 7+2
  • Motherboard Support E-ATX*
  • Color(s) Gun Metal / Black
  • I/O Panel 2x USB 2.0
  • Motherboard Support ATX
  • Clearance - PSU 220mm
  • Materials Mesh
  • Dimensions (L x W x H) 544 x 242 x 542mm / 21.4 x 9.5 x 21.3 inch
  • Fan Support - Top 2x 200mm
  • Expansion Slots (Supports vertical graphics card installation)
  • Motherboard Support (*support for up to 12" x 10.7", will limit cable management features)
  • Clearance - CPU Cooler 190mm
  • Pre-installed Fans - Front 2x 200mm ARGB Fan
  • I/O Panel 1x 3.5mm Mic Jack
  • Clearance - GFX 412mm
  • Weight 11.3 kg
  • I/O Panel 1x ARGB Controller
  • I/O Panel 1x ARGB 2-to-3 splitter
  • Model Number MCM-H500P-MGNN-S01
