MasterCase H500M image number 0
MasterCase H500M image number 1
MasterCase H500M image number 2
MasterCase H500M image number 3
MasterCase H500M image number 4
MasterCase H500M image number 5
MasterCase H500M image number 6
MasterCase H500M image number 7
MasterCase H500M image number 8
MasterCase H500M image number 9
MasterCase H500M image number 10
MasterCase H500M image number 11
MasterCase H500M image number 12
MasterCase H500M image number 13
MasterCase H500M image number 14
MasterCase H500M image number 15
MasterCase H500M
MasterCase H500M
MasterCase H500M
MasterCase H500M
MasterCase H500M
MasterCase H500M
MasterCase H500M
MasterCase H500M
MasterCase H500M
MasterCase H500M
MasterCase H500M
MasterCase H500M
MasterCase H500M
MasterCase H500M
MasterCase H500M
MasterCase H500M
Mind-blowing Design
MasterCase H500M
Interchangeable Front Panels
Addressable RGB Fans & Controller
Four Tempered Glass Panels
Adjustable Graphics Card Support Arm
Watercooling Support
Covers for Clean Building
Rich Connectivity
  • Series MasterCase Series
  • Materials - Body Steel
  • Materials - Outlook Steel Mesh
  • Materials - Outlook Glass
  • Drive Bays - 2.5" SSD 6
  • 5.25" Drive Bays 0
  • Radiator Support - Rear 140mm
  • Size Mid Tower
  • Fan Support - Top 2x 140/200mm
  • Fan Support - Front 2x 200mm Fan
  • Radiator Support - Top 360mm
  • Radiator Support - Top 280mm
  • Pre-installed Fans - Rear 1x 140mm fan (Speed: 1200RPM / Connector: 3Pin)
  • Expansion Slots 7+2
  • Motherboard Support E-ATX
  • Clearance - PSU 200mm
  • Motherboard Support ATX
  • Pre-installed Fans - Front 2x 200mm ARGB Fan (Speed: 800RPM / Connector: 3Pin + ARGB 3pin)
  • EAN Code 4719512072165
  • UPC Code 884102044663
  • Dimensions (L x W x H) 544 x 248 x 546mm / 21.4 x 9.8 x 21.5 inch
  • Fan Support - Top 3x 120mm
  • I/O Panel 4x USB 3.0 Type-A
  • Color(s) Iron Grey
  • I/O Panel 1x USB 3.1 Type-C
  • Clearance - CPU Cooler 190mm
  • Clearance - GFX 412mm
  • Model Number MCM-H500M-IHNN-S00
