MasterCase H500 image number 0
MasterCase H500 image number 1
MasterCase H500 image number 2
MasterCase H500 image number 3
MasterCase H500 image number 4
MasterCase H500 image number 5
MasterCase H500 image number 6
MasterCase H500 image number 7
MasterCase H500 image number 8
MasterCase H500 image number 9
MasterCase H500 image number 10
MasterCase H500 image number 11
MasterCase H500 image number 12
MasterCase H500 image number 13
MasterCase H500 image number 14
MasterCase H500 image number 15
MasterCase H500
MasterCase H500
MasterCase H500
MasterCase H500
MasterCase H500
MasterCase H500
MasterCase H500
MasterCase H500
MasterCase H500
MasterCase H500
MasterCase H500
MasterCase H500
MasterCase H500
MasterCase H500
MasterCase H500
MasterCase H500
MIND-BLOWING DESIGN
MasterCase H500
MasterCase H500
  • Series MasterCase Series
  • Dust Filters Top
  • Materials - Body Steel
  • I/O Port - Power-LED Color White
  • I/O Port - HDD-LED Color White
  • I/O Port - USB-Ports 2x USB 2.0
  • I/O Port - Audio In/Out Yes (support HD audio)
  • I/O Port - Reset Switch Yes
  • RGB Control Onboard button on the RGB Controller or via the Reset Switch (1x 1-to-3 RGB Splitter Cable Included)
  • 5.25" Drive Bays N/A
  • Fan Support - Front 2x 200mm
  • Cable Routing - Behind Motherboard Tray 30mm
  • Legacy Cases
  • I/O Port - USB-Ports 2x USB 3.0
  • Dust Filters Front
  • Size Mid Tower
  • Materials Plastic
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Fan Support - Rear 1x 120mm
  • Clearance - PSU 180mm/7.1"
  • Radiator Support - Front 200mm
  • Drive Bays - 2.5" SSD 2
  • Pre-installed Fans - Front 2x 200mm RGB Fan
  • EAN Code 4719512072172
  • UPC Code 884102044670
  • Motherboard Support ATX
  • Expansion Slots 7
  • Fan Support - Top 1x 200mm
  • Fan Support - Top 2x 140mm
  • Materials Mesh
  • Color(s) Iron Grey
  • Clearance - CPU Cooler 167mm/6.5"
  • Fan Support - Top 2x 120mm
  • Clearance - GFX 410mm/16.1"
  • Materials Mesh (Front Panel)
  • Materials Acrylic & Plastic (Front Panel)
  • Materials Steel & Plastic (Top Panel)
  • Materials Tempered Glass (Left Side Panel)
  • Materials Steel (Right Side Panel)
  • Dimensions (L x W x H) 525 x 228 x 502mm (Incl. Panels)
  • Dimensions (L x W x H) 450 x 220 x 445mm (Excl. Panels)
  • Model Number MCM-H500-IGNN-S00
