MasterCase H100 Mini-ITX PC Case image number 0
MasterCase H100 Mini-ITX PC Case image number 1
MasterCase H100 Mini-ITX PC Case image number 2
MasterCase H100 Mini-ITX PC Case image number 3
MasterCase H100 Mini-ITX PC Case image number 4
MasterCase H100 Mini-ITX PC Case image number 5
MasterCase H100 Mini-ITX PC Case image number 6
MasterCase H100 Mini-ITX PC Case image number 7
MasterCase H100 Mini-ITX PC Case image number 8
MasterCase H100 Mini-ITX PC Case image number 9
A Little Game-Changer
The MasterCase H100 remains fiercely loyal to the H Series, unwilling to part from the 200mm RGB fan despite its mini-ITX form factor.
  • Materials Steel
  • Dust Filters Top
  • 2.5" / 3.5" Drive Bays (Combo) 1
  • Legacy Cases
  • Dust Filters Front
  • Materials Plastic
  • 5.25" Drive Bays 0
  • Radiator Support - Front 200mm
  • Color(s) Iron Grey
  • Expansion Slots 2
  • Clearance - PSU 210mm (w/o radiator installed)
  • Clearance - PSU 160mm (with radiator installed)
  • Pre-installed Fans - Front 1 x 200mm RGB Fan (Speed: 800RPM / Connector: 3Pin + RGB 4pin)
  • Fan Support - Front 1x 120mm / 1x 140mm / 1x 200mm
  • Clearance - CPU Cooler 83mm
  • Materials Steel mesh
  • I/O Panel 1x 3.5mm Mic Jack
  • Clearance - GFX 210mm (w/o radiator installed)
  • Clearance - GFX 180mm (with radiator installed)
  • I/O Panel 1x RGB Controller
  • 2.5" Drive Bays 4 (3+1 combo)
  • UPC Code 884102061400
  • EAN Code 4719512088951
  • Dimensions (L x W x H) 312mm x 216mm x 301mm (incl. Protrusions)
  • Dimensions (L x W x H) 278mm x 216mm x 294mm (excl. Protrusions)
  • Model Number MCM-H100-KANN-S00
