WITH FREEFORM™ MODULAR SYSTEM
MasterCase 5
MasterCase 5
SeriesMasterCase Series
Radiator Support - Rear120mm
Power Supply SupportBottom Mount
Dust FiltersTop
Liquid Cooling Support - Top240mm/280mm radiator (max 320mm radiator)
Cooling Support - Top2x 120/140mm (Optional)
Cable Management25mm
Dust FiltersFront
MaterialsPlastic
Radiator Support - Rear140mm
3.5" Drive Bays2
I/O Panel2x USB 3.0
SizeMid Tower
LegacyCases
Dust FiltersBottom
Cooling Support - Rear1x 140mm (Pre-installed)
5.25" Drive Bays2
Power Supply SupportATX PS2
Drive Bays - 2.5" SSD2 + 2
Cooling Support - Front1x 140mm (Pre-installed)
Cooling Support - Front2x 120/140mm (Optional)
MaterialsSECC
Expansion Slots7
Motherboard SupportATX
Motherboard SupportMicro ATX
Motherboard SupportMini ITX
Color(s)Dark metallic grey exterior with black interior
Dimensions (L x W x H)512 x 235 x 548 mm
EAN Code4719512048283 (MCX-0005-KKN00)
UPC Code884102027246 (MCX-0005-KKN00)
UPC Code884102028595 (MCX-0005-KWN00)
EAN Code4719512052488 (MCX-0005-KWN00)
I/O PanelAudio In & Out (Supports HD Audio)
Maximum Compatibility - CPU Cooler Height190mm/7.5 inch
Weight10.6 kg / 23.4 lb
Maximum Compatibility - VGA Card Length412mm / 16.2 inch (w/o 3.5" HDD Cage)
Maximum Compatibility - VGA Card Length296mm / 11.7 inch (w/ 3.5" HDD Cage)
Dimensions (L x W x H)460(L) x 235(W) x 460(H) mm (Body)
Model NumberMCX-0005-KWN00 (windowed)
Model NumberMCX-0005-KKN00 (not windowed)
