MasterBox TD500 Crystal Mid Tower Case image number 0
MasterBox TD500 Crystal Mid Tower Case image number 1
MasterBox TD500 Crystal Mid Tower Case image number 2
MasterBox TD500 Crystal Mid Tower Case image number 3
MasterBox TD500 Crystal Mid Tower Case image number 4
MasterBox TD500 Crystal Mid Tower Case image number 5
MasterBox TD500 Crystal Mid Tower Case image number 6
Crystal Clear Finesse
The MasterBox TD500 Crystal makes you stand out from the rest with a three-dimensional diamond-cut design
  • Dust Filters Top
  • 5.25" Drive Bays N/A
  • Materials - Exterior Steel
  • Dust Filters Front
  • Color(s) Black
  • Series MasterBox Series
  • Size Mid Tower
  • Dust Filters Bottom
  • Radiator Support - Top 360mm
  • Power Supply Support ATX
  • Clearance - PSU 180mm/7.08"
  • Materials - Exterior Plastic
  • Fan Support - Rear 1x 120mm
  • Motherboard Support E-ATX*
  • Expansion Slots 7
  • Motherboard Support ATX
  • Cable Routing 19mm/0.74"
  • Fan Support - Top 2x 140mm
  • Fan Support - Top 3x 120mm
  • Radiator Support - Top (44mm max motherboard component height)
  • Motherboard Support (*up to 12" x 10.7" motherboards, may impact cable management feature)
  • Clearance - GFX 410mm/16.1"
  • 2.5" Drive Bays 4 (2+2 combo)
  • I/O Panel 2x USB 3.2 Gen 1 (USB 3.0), 1x 3.5mm Audio Jack, 1x 3.5mm Mic Jack, 1x ARGB Hub
  • Dimensions (L x W x H) 493 x 217 x 469mm (incl. Protrusions), 429.5 x 205 x 447mm (excl. Protrusions)
  • Model Number MCB-D500D-KGNN-SAU
  • MasterBox TD500 Crystal - Product Sheet (CF120 upgrade after 2022 upgrade) Download
  • MasterBox TD500 Crystal - Product Sheet (ARGB PWM Hub SN after 2022 upgrade) Download
  • MasterBox TD500 Crystal - Manual Download
  • Small ARGB Controller - Product Sheet Download
  • ARGB PWM HUB - Product Sheet Download
