MasterBox TD500 ARGB Mid Tower Case image number 0
MasterBox TD500 ARGB Mid Tower Case image number 1
MasterBox TD500 ARGB Mid Tower Case image number 2
MasterBox TD500 ARGB Mid Tower Case image number 3
MasterBox TD500 ARGB Mid Tower Case image number 4
MasterBox TD500 ARGB Mid Tower Case image number 5
MasterBox TD500 ARGB Mid Tower Case image number 6
MasterBox TD500 ARGB Mid Tower Case image number 7
MasterBox TD500 ARGB Mid Tower Case image number 8
MasterBox TD500 ARGB Mid Tower Case image number 9
MasterBox TD500 ARGB Mid Tower Case image number 10
MasterBox TD500 ARGB Mid Tower Case image number 11
Show Off Your Style
The MasterBox TD500 ARGB ATX case approaches PC lighting in a completely new perspective.
  • Dust Filters Top
  • 5.25" Drive Bays N/A
  • Dust Filters Front
  • Color(s) Black
  • Series MasterBox Series
  • Size Mid Tower
  • Materials - Exterior Steel
  • Materials - Exterior Plastic
  • Dust Filters Bottom
  • Radiator Support - Top 360mm
  • Power Supply Support ATX
  • Clearance - PSU 180mm/7.08"
  • Fan Support - Rear 1x 120mm
  • Motherboard Support E-ATX*
  • Materials - Left Side Panel Acrylic
  • Expansion Slots 7
  • Motherboard Support ATX
  • Cable Routing 19mm/0.74"
  • Fan Support - Top 2x 140mm
  • Fan Support - Top 3x 120mm
  • Radiator Support - Top (44mm max motherboard component height)
  • Motherboard Support (*up to 12" x 10.7" motherboards, may impact cable management feature)
  • Clearance - GFX 410mm/16.1"
  • 2.5" Drive Bays 4 (2+2 combo)
  • I/O Panel 2x USB 3.2 Gen 1 (USB 3.0), 1x 3.5mm Audio Jack, 1x 3.5mm Mic Jack, 1x ARGB Hub
  • Dimensions (L x W x H) 493 x 217 x 469mm (incl. Protrusions)
  • Dimensions (L x W x H) 429.5 x 205 x 447mm (excl. Protrusions)
  • Model Number MCB-D500D-KANN-S01
  • MasterBox TD500 ARGB - Product Sheet (CF120 upgrade after 2022 upgrade) Download
  • MasterBox TD500 ARGB - Product Sheet (ARGB Controller SN before 2022 update) Download
  • MasterBox TD500 ARGB - Product Sheet (ARGB PWM Hub SN after 2022 upgrade) Download
  • MasterBox TD500 ARGB - Manual Download
  • Small ARGB Controller - Product Sheet Download
  • ARGB PWM HUB - Product Sheet Download
