MasterBox Q500L Sakura Edition image number 0
MasterBox Q500L Sakura Edition image number 1
MasterBox Q500L Sakura Edition image number 2
MasterBox Q500L Sakura Edition image number 3
MasterBox Q500L Sakura Edition image number 4
MasterBox Q500L Sakura Edition image number 5
MasterBox Q500L Sakura Edition image number 6
MasterBox Q500L Sakura Edition image number 7
MasterBox Q500L Sakura Edition image number 8
MasterBox Q500L Sakura Edition image number 9
Choose Your Style
Highly Compact Standard ATX
Orientation & A Movable I/O Panel
Versatile PSU Bracket
Fully Perforated Chassis
Magnetic Dust Filters
Edge-to-Edge Transparent Side Panel
Clean Routing Space
  • Materials - Body Steel
  • 2.5" Drive Bays 0
  • Fan Support - Bottom 2x 120mm
  • Materials - Body Plastic
  • I/O Panel 2x USB 3.0
  • 5.25" Drive Bays 0
  • Series MasterBox Series
  • Size Mid Tower
  • Dust Filters Bottom
  • Clearance - PSU 180mm/7.08"
  • 2.5" / 3.5" Drive Bays (Combo) 2 (each bay supports: 1 HDD or 2 SSDs)
  • Exterior Color White
  • Fan Support - Rear 1x 120mm
  • Materials - Side Panel Acrylic
  • Expansion Slots 7
  • Motherboard Support ATX
  • Cable Routing 27-30mm
  • Clearance - CPU Cooler 160mm/6.29"
  • Radiator Support - Top 120 / 240mm (35mm max motherboard component height)
  • Pre-installed Fans - Rear 1x 120mm ARGB Fan
  • Clearance - GFX 360mm/14.17" (270mm clearance with PSUs longer than 160mm)
  • Power Supply Support Top Front Mount
  • I/O Panel 1x 3.5mm Mic Jack
  • Dimensions (L x W x H) 386 (L) x 230 (W) x 381 (H) mm
  • Model Number Q500L-KANN-SJP
