MasterBox Q500L image number 0
MasterBox Q500L image number 1
MasterBox Q500L image number 2
MasterBox Q500L image number 3
MasterBox Q500L image number 4
MasterBox Q500L image number 5
MasterBox Q500L image number 6
MasterBox Q500L image number 7
MasterBox Q500L image number 8
MasterBox Q500L image number 9
MasterBox Q500L image number 10
MasterBox Q500L image number 11
MasterBox Q500L image number 12
MasterBox Q500L image number 13
MasterBox Q500L image number 14
MasterBox Q500L image number 15
MasterBox Q500L image number 16
MasterBox Q500L image number 17
MasterBox Q500L
MasterBox Q500L
MasterBox Q500L
MasterBox Q500L
MasterBox Q500L
MasterBox Q500L
MasterBox Q500L
MasterBox Q500L
MasterBox Q500L
MasterBox Q500L
MasterBox Q500L
MasterBox Q500L
MasterBox Q500L
MasterBox Q500L
MasterBox Q500L
MasterBox Q500L
MasterBox Q500L
MasterBox Q500L
Choose Your Style
MasterBox Q500L
Highly Compact Standard ATX
Orientation & A Movable I/O Panel
Versatile PSU Bracket
Fully Perforated Chassis
Magnetic Dust Filters
Edge-to-Edge Transparent Side Panel
Clean Routing Space
  • Model Number MCB-Q500L-KANN-S00
  • Exterior Color Black
  • Materials - Body Steel, Plastic
  • Materials - Side Panel Acrylic
  • Dimensions (L x W x H) 386 (L) x 230 (W) x 381 (H) mm
  • Motherboard Support Mini-ITX, Micro-ATX, ATX, E-ATX (support up to 12" x 10.7")
  • Expansion Slots 7
  • 5.25" Drive Bays 0
  • 2.5" / 3.5" Drive Bays (Combo) 2 (each bay supports: 1 HDD or 2 SSDs)
  • 2.5" Drive Bays 0
  • I/O Panel - Audio In / Out 1x 3.5mm Audio Jack, 1x 3.5mm Mic Jack
  • Fan Support - Rear 1x 120mm
  • Fan Support - Bottom 2x 120mm
  • Radiator Support - Top 120 / 240mm (35mm max motherboard component height)
  • Clearance - CPU Cooler 160mm/6.29"
  • Clearance - PSU 180mm/7.08"
  • Clearance - GFX 360mm/14.17" (270mm clearance with PSUs longer than 160mm)
  • Cable Routing 27-30mm
  • Dust Filters Bottom
  • Power Supply Support Top Front Mount, ATX PS2
  • Size Mid Tower
  • Series MasterBox Series
