MasterBox Q300P Mini Tower PC Case image number 0
MasterBox Q300P Mini Tower PC Case image number 1
MasterBox Q300P Mini Tower PC Case image number 2
MasterBox Q300P Mini Tower PC Case image number 3
MasterBox Q300P Mini Tower PC Case image number 4
MasterBox Q300P Mini Tower PC Case image number 5
MasterBox Q300P Mini Tower PC Case image number 6
MasterBox Q300P Mini Tower PC Case image number 7
MasterBox Q300P Mini Tower PC Case image number 8
MasterBox Q300P Mini Tower PC Case image number 9
MasterBox Q300P Mini Tower PC Case image number 10
MasterBox Q300P Mini Tower PC Case image number 11
MasterBox Q300P Mini Tower PC Case image number 12
MasterBox Q300P Mini Tower PC Case image number 13
MasterBox Q300P Mini Tower PC Case image number 14
MasterBox Q300P Mini Tower PC Case image number 15
Choose Your Style
The MasterBox Q300P is your portable option in the lineup of the brand new MasterBoxQ-series from Cooler Master.
  • Materials Steel
  • 3.5" Drive Bays 1
  • Dust Filters Top
  • Dust Filters Front
  • 5.25" Drive Bays 0
  • I/O Panel 2x USB 3.0
  • Materials Plastic
  • Color(s) Black
  • Series MasterBox Series
  • Size Mini Tower
  • 2.5" Drive Bays 2
  • Dust Filters Bottom
  • Fan Support - Rear 1x 120mm
  • Power Supply Support ATX PS2 / EPS 12V
  • Clearance - CPU Cooler 159mm
  • Expansion Slots 4
  • Pre-installed Fans - Front 2x 120mm RGB LED Fan
  • Clearance - GFX 360mm
  • Fan Support - Top 2x 120mm
  • Dimensions (L x W x H) 453 x 230 x 453mm
  • Model Number MCB-Q300P-KANN-S02
