You Decide the Inside
MasterBox Pro 5
MasterBox Pro 5
Power Supply SupportBottom Mount
Liquid Cooling Support - Rear120mm
LegacyCases
Warranty2 years
2.5" / 3.5" Drive Bays (Combo)2
Dust FiltersFront
Color(s)Black
SeriesMasterBox Series
SizeMid Tower
I/O Panel2x USB 3.0
Pre-installed Fans - Rear1x 120mm (Black)
Dust FiltersBottom
Power Supply SupportATX
Liquid Cooling Support - Front240mm
Left Side Panel4mm Grey Color Tempered Glass
Liquid Cooling Support - Front280mm
Clearance - PSU180mm/7.1"
Fan Support - Rear1x 120mm
Liquid Cooling Support - Front360mm
Fan Support - Front2x 140mm
Drive Bays - 2.5" SSD2
Motherboard SupportE-ATX
Motherboard SupportATX
Expansion Slots7
Motherboard SupportMicro ATX
Fan Support - Front3x 120mm
Cable Routing - Behind Motherboard Tray25-35mm
MaterialsSteel body
Motherboard SupportMini ITX
Clearance - CPU Cooler167mm/6.5"
MaterialsPlastic bezel
MaterialsGlass
Clearance - GFX410mm/16.1"
Dimensions (L x W x H)500 x 223 x 475 mm
Weight8.3 kg
I/O PanelAudio In & Out (Supports HD Audio)
EAN Code4719512063514
UPC Code884102036194
Model NumberMCY-B5P2-KWGN-00
