MasterBox NR600 without ODD image number 0
MasterBox NR600 without ODD image number 1
MasterBox NR600 without ODD image number 2
MasterBox NR600 without ODD image number 3
MasterBox NR600 without ODD image number 4
MasterBox NR600 without ODD image number 5
MasterBox NR600 without ODD image number 6
MasterBox NR600 without ODD image number 7
MasterBox NR600 without ODD image number 8
MasterBox NR600 without ODD image number 9
MasterBox NR600 without ODD image number 10
MasterBox NR600 without ODD image number 11
FORM & FUNCTION STREAMLINED
Minimalistic Design
Seamless Tempered Glass
Ample Storage Support
Headset Jack
Fan Support
Radiator Support
Component Clearances
  • Model Number MCB-NR600-KGNN-S00
  • Exterior Color Black
  • Materials - Body Steel, Plastic
  • Dimensions (L x W x H) 478 (L) x 209 (W) x 473 (H) mm
  • Motherboard Support Mini-ITX, Micro-ATX, ATX
  • Expansion Slots 7
  • 5.25" Drive Bays 0
  • 3.5" Drive Bays 4
  • 2.5" Drive Bays 5
  • Pre-installed Fans - Front 1x 120mm
  • Fan Support - Front 3x 120mm, 2x 140mm
  • Fan Support - Top 2x 120mm, 2x 140mm
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Front 120 / 140 / 240 / 280 / 360mm
  • Radiator Support - Top 120 / 240mm (35mm max motherboard component height)
  • Clearance - CPU Cooler 166mm
  • Clearance - PSU 160mm
  • Clearance - GFX 410mm
  • Cable Routing - Behind Motherboard Tray 20-28mm / 0.78-1.10"
  • Dust Filters Top, Bottom
  • Size Mid Tower
  • Series MasterBox Series
