MasterBox NR200P Color image number 0
MasterBox NR200P Color image number 1
MasterBox NR200P Color image number 2
MasterBox NR200P Color image number 3
MasterBox NR200P Color image number 4
MasterBox NR200P Color image number 5
MasterBox NR200P Color image number 6
MasterBox NR200P Color image number 7
MasterBox NR200P Color image number 8
MasterBox NR200P Color image number 9
MasterBox NR200P Color image number 10
MasterBox NR200P Color image number 11
MasterBox NR200P Color image number 12
MasterBox NR200P Color image number 13
MasterBox NR200P Color image number 14
MasterBox NR200P Color image number 15
MasterBox NR200P Color image number 16
MasterBox NR200P Color image number 17
MasterBox NR200P Color image number 18
MasterBox NR200P Color image number 19
4 New Colorways
Flamingo Pink
Caribbean Blue
Sunset Orange
Nightshade Purple
  • Materials Steel
  • Radiator Support - Bottom 120mm
  • Dust Filters Top
  • 2.5" / 3.5" Drive Bays (Combo) 1
  • Radiator Support - Side 120mm
  • Radiator Support - Side 140mm
  • Pre-installed Fans - Bottom N/A
  • 5.25" Drive Bays 0
  • Materials Plastic
  • Series MasterBox Series
  • Fan Support - Side 2x 120/140mm
  • Materials Tempered Glass
  • Radiator Support - Bottom 240mm
  • Dust Filters Bottom
  • Radiator Support - Side 240mm
  • Radiator Support - Rear 92mm (Not Compatible with Vertical GPU Installation)
  • Radiator Support - Side 280mm
  • Size Mini ITX
  • Dust Filters Left side
  • Volume 18.25L (exlc. Protrusions)
  • Dust Filters Right side
  • Radiator Support - Side (not compatible with vertical GPU installation)
  • Pre-installed Fans - Top 2x 120mm 650-1800RPM PWM (SickleFlow)
  • Radiator Support - Bottom (recommended for custom loops only)
  • Note Single slot water-cooler GPUs or vertically mounted GPUs are recommended when using bottom radiator position
  • Fan Support - Rear 1x 92mm
  • Fan Support - Bottom 2x 120mm (recommended slim fans for GPUs wider than 2.5 PCI slots)
  • Motherboard Support Mini DTX
  • Materials Mesh
  • Accessories 1x PCIe 3.0 x16 riser cable
  • Expansion Slots 3
  • Fan Support - Top 2x 120mm
  • Motherboard Support Max MB size: 244 x 226mm (L x H)
  • Radiator Support - Top N/A
  • I/O Panel 2x USB 3.2 Gen 1 Type-A
  • Clearance - PSU 130mm
  • Clearance - CPU Cooler 76mm (GPU in vertical position)
  • Power Supply Support SFX
  • Clearance - CPU Cooler 153mm (tempered glass side panel)
  • Clearance - CPU Cooler 155mm (vented steel side panel)
  • Power Supply Support SFX-L
  • I/O Panel 1x 3.5mm Headset Jack (Audio+Mic)
  • 3.5" Drive Bays 1 (Max. 2)
  • Clearance - GFX L: 330mm (incl. power connector)
  • Clearance - GFX H: 156mm (incl. power connector)
  • Weight 5.93 kg
  • Clearance - GFX W: 60mm (triple slot)
  • Color(s) Purple/Black
  • Color(s) Orange/Black
  • Color(s) Cyan/White
  • 2.5" Drive Bays 2 (Max. 3)
  • Color(s) Pink/White
  • Dimensions (L x W x H) 376 x 185 x 292mm incl. Protrusions
  • Dimensions (L x W x H) 360 x 185 x 274mm excl. Protrusions
  • Model Number MCB-NR200P-PCNN-S00 (Nightshade Purple)
  • Model Number MCB-NR200P-OCNN-S00 (Sunset Orange)
  • Model Number MCB-NR200P-ACNN-S00 (Caribbean Blue)
  • Model Number MCB-NR200P-QCNN-S00 ( Flamingo Pink)
