MasterBox MB600L V2 image number 0
MasterBox MB600L V2 image number 1
MasterBox MB600L V2 image number 2
MasterBox MB600L V2 image number 3
MasterBox MB600L V2 image number 4
MasterBox MB600L V2 image number 5
MasterBox MB600L V2 image number 6
MasterBox MB600L V2 image number 7
MasterBox MB600L V2 image number 8
MasterBox MB600L V2 image number 9
MasterBox MB600L V2 image number 10
MasterBox MB600L V2 image number 11
MasterBox MB600L V2 image number 12
MasterBox MB600L V2 image number 13
MasterBox MB600L V2
MasterBox MB600L V2
MasterBox MB600L V2
MasterBox MB600L V2
MasterBox MB600L V2
MasterBox MB600L V2
MasterBox MB600L V2
MasterBox MB600L V2
MasterBox MB600L V2
MasterBox MB600L V2
MasterBox MB600L V2
MasterBox MB600L V2
MasterBox MB600L V2
MasterBox MB600L V2
Sensible By Design
MasterBox MB600L V2
Brushed Front Panel
Hexagon Gleam
Mesh Intakes
With/Without ODD Support
Versatile Cooling Options
Room For Upgrades
Removable HDD Cage
  • Materials Steel
  • Dust Filters Top
  • Dust Filters Front
  • Materials Plastic
  • Color(s) Black
  • Series MasterBox Series
  • Size Mid Tower
  • 2.5" Drive Bays 2
  • Materials Tempered Glass
  • Power Supply Support ATX
  • Dust Filters Bottom
  • Fan Support - Rear 1x 120mm
  • Expansion Slots 7
  • Motherboard Support ATX
  • Volume 37.15L (MB600L2-K*NN-S00) (exlc. Protrusions), 42.26L (MB600L2-K*5N-S00) (exlc. Protrusions)
  • Cable Routing 18.5mm
  • I/O Panel 2x USB 3.2 Gen 1 Type-A
  • Radiator Support - Front 360mm (remove & reinstall ODD bracket to mount 360mm radiator (MB600L2-K*5N-S00)
  • Radiator Support - Top (RAM height limit 32mm; install RAM first, then install radiator)
  • Fan Support - Front 3x 120mm (remove ODD bracket) (MB600L2-K*5N-S00)
  • Clearance - PSU 160mm (MB600L2-K*NN-S00), 180mm (MB600L2-K*5N-S00)
  • I/O Panel 1x 3.5mm Headset Jack (Audio+Mic)
  • Clearance - CPU Cooler 161mm
  • 5.25" Drive Bays 0 (MB600L2-K*NN-S00), 1 (MB600L2-K*5N-S00)
  • Clearance - GFX 350mm (w/o front fans & radiator) (MB600L2-K*NN-S00), 400mm (w/o front fans & radiator) (MB600L2-K*5N-S00)
  • Dimensions (L x W x H) 405.5x204x455.3mm (incl. Protrusions) (MB600L2-K*NN-S00), 400x204x455.3mm (excl. Protrusions) (MB600L2-K*NN-S00), 460.5x204x455.3mm (incl. Protrusions) (MB600L2-K*5N-S00), 455x204x455.3mm (excl. Protrusions) (MB600L2-K*5N-S00)
  • Model Number MB600L2-KGNN-S00 (w/o ODD TG), MB600L2-KNNN-S00 (w/o ODD Steel), MB600L2-KG5N-S00 (w/ ODD TG), MB600L2-KN5N-S00 (w/ ODD Steel)
