MasterBox MB520 TG Mid Tower PC Case image number 0
MasterBox MB520 TG Mid Tower PC Case image number 1
MasterBox MB520 TG Mid Tower PC Case image number 2
MasterBox MB520 TG Mid Tower PC Case image number 3
MasterBox MB520 TG Mid Tower PC Case image number 4
MasterBox MB520 TG Mid Tower PC Case image number 5
LIGHT 'EM UP.
The MasterBox MB520 TG focuses on aesthetics and showmanship with a fully transparent front panel. For rigs built with lighting as a concentration
  • Materials Steel
  • Dust Filters Top
  • 5.25" Drive Bays N/A
  • Dust Filters Front
  • I/O Panel 2x USB 3.0
  • Materials Plastic
  • Legacy Cases
  • Materials Tempered Glass
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Fan Support - Rear 1x 120mm
  • Clearance - PSU 180mm/7.1"
  • 2.5" / 3.5" Drive Bays (Combo) 2 (Max.2)
  • Expansion Slots 7
  • Motherboard Support ATX
  • Fan Support - Top 2x 140mm
  • Cable Routing - Behind Motherboard Tray 19-27mm / 0.74-1.06"
  • Fan Support - Top 2x 120mm
  • Color(s) Red
  • Clearance - GFX 410mm/16.1"
  • 2.5" Drive Bays 4 (Max.6)
  • UPC Code 884102047558
  • EAN Code 4719512075067
  • Dimensions (L x W x H) 496 x 218 x 468mm
  • Model Number MCB-B520-KGNN-S00
