MasterBox MB511 TG Mid Tower PC Case image number 0
MasterBox MB511 TG Mid Tower PC Case image number 1
MasterBox MB511 TG Mid Tower PC Case image number 2
MasterBox MB511 TG Mid Tower PC Case image number 3
MasterBox MB511 TG Mid Tower PC Case image number 4
MasterBox MB511 TG Mid Tower PC Case image number 5
MasterBox MB511 TG Mid Tower PC Case image number 6
MasterBox MB511 TG Mid Tower PC Case image number 7
MasterBox MB511 TG Mid Tower PC Case image number 8
MasterBox MB511 TG Mid Tower PC Case image number 9
PLAY IT COOL.
With the MasterBoxMB511 TG, systems built for high demand gaming can breathe easy through the mesh front panel. Along with the aggressive intakes
  • Materials Steel
  • Dust Filters Top
  • 5.25" Drive Bays N/A
  • Liquid Cooling Support - Front 120mm
  • Liquid Cooling Support - Rear 120mm
  • Liquid Cooling Support - Top 120mm
  • Liquid Cooling Support - Front 140mm
  • I/O Panel 2x USB 3.0
  • Dust Filters Front
  • Materials Plastic
  • Legacy Cases
  • Materials Tempered Glass
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Liquid Cooling Support - Front 240mm
  • Cable Routing - Behind Motherboard Tray 19mm / 0.74"
  • Clearance - PSU 180mm/7.08"
  • Fan Support - Rear 1x 120mm
  • Liquid Cooling Support - Front 280mm
  • Liquid Cooling Support - Top 240mm
  • 2.5" / 3.5" Drive Bays (Combo) 2 (Max.2)
  • Liquid Cooling Support - Front 360mm
  • Expansion Slots 7
  • Motherboard Support ATX
  • Fan Support - Top 2x 140mm
  • Fan Support - Top 2x 120mm
  • Color(s) Red
  • Dimensions (L x W x H) 496 x 217 x 468 mm
  • Clearance - GFX 410mm/16.1"
  • 2.5" Drive Bays 5 (Max.6)
  • UPC Code 884102045189
  • EAN Code 4719512072691
  • Model Number MCB-B511D-KGNN-S00
