MasterBox MB510L image number 0
MasterBox MB510L image number 1
MasterBox MB510L image number 2
MasterBox MB510L image number 3
MasterBox MB510L image number 4
MasterBox MB510L image number 5
MasterBox MB510L image number 6
MasterBox MB510L image number 7
MasterBox MB510L image number 8
MasterBox MB510L image number 9
MasterBox MB510L image number 10
MasterBox MB510L image number 11
MasterBox MB510L image number 12
MasterBox MB510L
MasterBox MB510L
MasterBox MB510L
MasterBox MB510L
MasterBox MB510L
MasterBox MB510L
MasterBox MB510L
MasterBox MB510L
MasterBox MB510L
MasterBox MB510L
MasterBox MB510L
MasterBox MB510L
MasterBox MB510L
READY, SET, GAME.
MasterBox MB510L
MasterBox MB510L
  • Materials Steel
  • 5.25" Drive Bays N/A
  • Liquid Cooling Support - Front 120mm
  • Liquid Cooling Support - Rear 120mm
  • Liquid Cooling Support - Top 120mm
  • Liquid Cooling Support - Front 140mm
  • Dust Filters Front
  • Materials Plastic
  • I/O Panel 2x USB 3.0
  • Color(s) Black
  • Series MasterBox Series
  • Note * Availability may vary depending on region
  • Legacy Cases
  • Cable Routing - Behind Motherboard Tray 19mm / 0.74"
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Color(s) White
  • Liquid Cooling Support - Front 240mm
  • Liquid Cooling Support - Front 280mm
  • Fan Support - Rear 1x 120mm
  • Clearance - PSU 180mm/7.1"
  • Liquid Cooling Support - Top 240mm
  • Liquid Cooling Support - Front 360mm
  • Expansion Slots 7
  • Motherboard Support ATX
  • Fan Support - Top 2x 140mm
  • Fan Support - Top 2x 120mm
  • Color(s) Red
  • Color(s) Blue
  • Dimensions (L x W x H) 496 x 217 x 468 mm
  • Dimensions (L x W x H) 523 x 276 x 568 mm
  • EAN Code 4719512072196 (MCB-B510L-KANN-S00, Red)
  • UPC Code 884102044694 (MCB-B510L-KANN-S00, Red)
  • UPC Code 884102044687 (MCB-B510L-KANN-S01, Black)
  • EAN Code 4719512072189 (MCB-B510L-KANN-S01, Black)
  • EAN Code 4719512072202 (MCB-B510L-KANN-S02, White)
  • UPC Code 884102044700 (MCB-B510L-KANN-S02, White)
  • UPC Code 884102044717 (MCB-B510L-KANN-S03, Blue)
  • EAN Code 4719512072219 (MCB-B510L-KANN-S03, Blue)
  • Clearance - GFX 410mm/16.1"
  • 2.5" Drive Bays 4 (Max.6)
  • Model Number MCB-B510L-KANN-S03 (Blue)
  • Model Number MCB-B510L-KANN-S02 (White)
  • Model Number MCB-B510L-KANN-S01 (Black)
  • Model Number MCB-B510L-KANN-S00 (Red)
