MasterBox MB500 image number 0
MasterBox MB500 image number 1
MasterBox MB500 image number 2
MasterBox MB500 image number 3
MasterBox MB500 image number 4
MasterBox MB500 image number 5
MasterBox MB500 image number 6
MasterBox MB500 image number 7
MasterBox MB500 image number 8
MasterBox MB500 image number 9
MasterBox MB500 image number 10
MasterBox MB500
MasterBox MB500
MasterBox MB500
MasterBox MB500
MasterBox MB500
MasterBox MB500
MasterBox MB500
MasterBox MB500
MasterBox MB500
MasterBox MB500
MasterBox MB500
YOU DECIDE THE INSIDE
MasterBox MB500
MasterBox MB500
  • Materials Steel
  • Materials Plastic
  • Dust Filters Front
  • 3.5" Drive Bays 2
  • I/O Panel 2x USB 3.0
  • Color(s) Black
  • Legacy Cases
  • Dust Filters Bottom
  • Materials Tempered Glass
  • Power Supply Support ATX
  • Fan Support - Rear 1x 120mm
  • Clearance - PSU 180mm/7.1"
  • Pre-installed Fans - Rear 1x 120mm RGB LED Fan
  • Expansion Slots 7
  • Motherboard Support ATX
  • Drive Bays - 2.5" SSD 2 (Max. 4)
  • Clearance - CPU Cooler 163mm/6.41"
  • Pre-installed Fans - Front 2x 120mm RGB LED Fan
  • Fan Support - Top 2x 120mm
  • Cable Routing - Behind Motherboard Tray 15-23mm / 0.59-0.90"
  • Clearance - GFX 400mm
  • Dimensions (L x W x H) 494 x 211 x 475mm
  • EAN Code 4719512067345
  • UPC Code 884102039867
  • Model Number MCB-B500D-KGNN-S00
