MasterBox MB500 ARGB Mid Tower PC Case image number 0
MasterBox MB500 ARGB Mid Tower PC Case image number 1
MasterBox MB500 ARGB Mid Tower PC Case image number 2
MasterBox MB500 ARGB Mid Tower PC Case image number 3
MasterBox MB500 ARGB Mid Tower PC Case image number 4
MasterBox MB500 ARGB Mid Tower PC Case image number 5
MasterBox MB500 ARGB Mid Tower PC Case image number 6
MasterBox MB500 ARGB Mid Tower PC Case image number 7
MasterBox MB500 ARGB Mid Tower PC Case image number 8
You Decide The Inside
The MasterBox MB500 ARGB is an airflow-centric, ATX gaming PC case with pre-installed ARGB fans—all without breaking the bank.
  • Materials Steel
  • Dust Filters Top
  • 5.25" Drive Bays N/A
  • Legacy Cases
  • Dust Filters Front
  • Materials Plastic
  • Color(s) Black
  • Materials Tempered Glass
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Fan Support - Rear 1x 120mm
  • Clearance - PSU 180mm/7.1"
  • 2.5" / 3.5" Drive Bays (Combo) 2 (Max.2)
  • Motherboard Support ATX
  • Expansion Slots 7
  • Clearance - CPU Cooler 163mm/6.41"
  • Pre-installed Fans - Rear 1x 120mm ARGB Fan
  • Radiator Support - Front (up to 50mm thickness without fan)
  • Fan Support - Top 2x 120mm
  • Dimensions (L x W x H) 494 x 211 x 475mm
  • Clearance - GFX 400mm
  • Pre-installed Fans - Front 2x 120mm ARGB Fan
  • 2.5" Drive Bays 2 (Max.4)
  • Weight 6.35 kg
  • I/O Panel 1x 3.5mm Mic Jack
  • I/O Panel 1x ARGB Controller
  • I/O Panel 1x ARGB 2-to-3 splitter
  • UPC Code 884102039867
  • EAN Code 4719512095164
  • Model Number MCB-B500D-KGNN-S01
