MasterBox MB400L with ODD Mini Tower PC Case image number 0
MasterBox MB400L with ODD Mini Tower PC Case image number 1
MasterBox MB400L with ODD Mini Tower PC Case image number 2
MasterBox MB400L with ODD Mini Tower PC Case image number 3
MasterBox MB400L with ODD Mini Tower PC Case image number 4
MasterBox MB400L with ODD Mini Tower PC Case image number 5
MasterBox MB400L with ODD Mini Tower PC Case image number 6
MasterBox MB400L with ODD Mini Tower PC Case image number 7
MasterBox MB400L with ODD Mini Tower PC Case image number 8
MasterBox MB400L with ODD Mini Tower PC Case image number 9
Sensible by design
Each element of the MasterBox MB400L was created from an elegant palette. With a brushed finish, subtle hue, and the minimalistic Cooler Master...
  • Materials Steel
  • Dust Filters Top
  • Clearance - PSU 140mm (HDD cage in backmost position)
  • Dust Filters Front
  • 3.5" Drive Bays 2
  • Materials Plastic
  • Color(s) Black
  • Series MasterBox Series
  • Size Mini Tower
  • 5.25" Drive Bays 1
  • 2.5" Drive Bays 2
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Fan Support - Rear 1x 120mm
  • Materials Mesh
  • Cable Routing 18-22mm
  • Clearance - PSU 325mm (w/o front radiator & HDD cage)
  • Fan Support - Top 1x 140mm
  • Fan Support - Front 2x 120mm
  • Expansion Slots 4
  • Fan Support - Top 1x 120mm
  • Radiator Support - Front 280mm (remove & reinstall ODD bracket to mount 280mm radiator)
  • Clearance - CPU Cooler Steel: 167mm
  • Fan Support - Front Mount behind the front plate
  • Weight 5.47kg
  • I/O Panel 1x 3.5mm Headset Jack (Audio+Mic)
  • Clearance - GFX 344mm
  • I/O Panel 2x USB 3.2 Gen 1 (USB 3.0)
  • Dimensions (L x W x H) 411 x 210 x 410mm (Steel Incl. Protrusions)
  • Dimensions (L x W x H) 396 x 210 x 400mm (Excl. Protrusions)
  • Model Number MCB-B400L-KN5N-S00
