MasterBox MB320L Mini Tower PC Case image number 0
MasterBox MB320L Mini Tower PC Case image number 1
MasterBox MB320L Mini Tower PC Case image number 2
MasterBox MB320L Mini Tower PC Case image number 3
MasterBox MB320L Mini Tower PC Case image number 4
MasterBox MB320L Mini Tower PC Case image number 5
MasterBox MB320L Mini Tower PC Case image number 6
MasterBox MB320L Mini Tower PC Case image number 7
MasterBox MB320L Mini Tower PC Case image number 8
MasterBox MB320L Mini Tower PC Case image number 9
MasterBox MB320L Mini Tower PC Case image number 10
MasterBox MB320L Mini Tower PC Case image number 11
Better after darkmirror
The MasterBox MB320L is a Micro-ATX PC case with honeycomb mesh ventilation on either side of the DarkMirror front panel.
  • Materials Steel
  • Dust Filters Top
  • 5.25" Drive Bays N/A
  • Clearance - PSU 140mm (HDD cage in backmost position)
  • Dust Filters Front
  • 3.5" Drive Bays 2
  • Materials Plastic
  • Color(s) Black
  • Series MasterBox Series
  • Size Mini Tower
  • 2.5" Drive Bays 2
  • Materials Tempered Glass
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Fan Support - Rear 1x 120mm
  • Materials Mesh
  • Cable Routing 18-22mm
  • Clearance - PSU 325mm (w/o front radiator & HDD cage)
  • Expansion Slots 4
  • Clearance - CPU Cooler 166mm/6.54"
  • Weight 5.28kg
  • I/O Panel 1x 3.5mm Mic Jack
  • Clearance - GFX 344mm
  • Dimensions (L x W x H) 435.5 x 217.5 x 410mm
  • Model Number MCB-B320L-KGNN-S00
