MasterBox Lite 5 RGB image number 0
MasterBox Lite 5 RGB image number 1
MasterBox Lite 5 RGB image number 2
MasterBox Lite 5 RGB image number 3
MasterBox Lite 5 RGB image number 4
MasterBox Lite 5 RGB image number 5
MasterBox Lite 5 RGB image number 6
MasterBox Lite 5 RGB image number 7
MasterBox Lite 5 RGB image number 8
MasterBox Lite 5 RGB image number 9
MasterBox Lite 5 RGB image number 10
MasterBox Lite 5 RGB image number 11
MasterBox Lite 5 RGB image number 12
MasterBox Lite 5 RGB image number 13
MasterBox Lite 5 RGB image number 14
MasterBox Lite 5 RGB image number 15
MasterBox Lite 5 RGB image number 16
Choose Your Style
  • Materials Steel
  • Liquid Cooling Support - Front 120mm
  • Liquid Cooling Support - Rear 120mm
  • 1 to 3 Splitter cable for RGB LED fan 1 to 3 Splitter cable for fan headers RGB Connector Splitter
  • 1 to 3 Splitter cable for RGB LED fan 1 to 3 Splitter cable for fan headers 4x4 pin male to male adapter
  • Liquid Cooling Support - Front 140mm
  • Dust Filters Front
  • Materials Plastic
  • I/O Panel 2x USB 3.0
  • Color(s) Black
  • Legacy Cases
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Liquid Cooling Support - Front 240mm
  • 1 to 3 Splitter cable for RGB LED fan 1 to 3 Splitter cable for fan headers Splitter cable for fan header
  • Liquid Cooling Support - Front 280mm
  • Drive Bays - SSD 1
  • Fan Support - Rear 1x 120mm
  • Clearance - PSU 180mm/7.1"
  • Liquid Cooling Support - Front 360mm
  • Expansion Slots 7
  • Motherboard Support ATX
  • Clearance - CPU Cooler 163mm/6.41"
  • Pre-installed Fans - Front 3x 120mm RGB Fan
  • Cable Routing - Behind Motherboard Tray 15-23mm / 0.59-0.90"
  • Clearance - GFX 400mm/16.14"
  • Clearance - GFX 400mm/16.14" (w/o 3.5" HDD cage)
  • Dimensions (L x W x H) 468.8 x 200 x 454.5mm
  • EAN Code 4719512063064 (MCW-L5S3-KGNN-02)
  • UPC Code 884102035746 (MCW-L5S3-KGNN-02)
  • UPC Code 884102041488 (MCW-L5S3-KGNN-03)
  • EAN Code 4719512068977 (MCW-L5S3-KGNN-03)
  • Model Number MCW-L5S3-KGNN-03 (w/ RGB Controller)
  • Model Number MCW-L5S3-KGNN-02
