MasterBox Lite 3 Mini Tower PC Case image number 0
MasterBox Lite 3 Mini Tower PC Case image number 1
MasterBox Lite 3 Mini Tower PC Case image number 2
MasterBox Lite 3 Mini Tower PC Case image number 3
MasterBox Lite 3 Mini Tower PC Case image number 4
MasterBox Lite 3 Mini Tower PC Case image number 5
Small Size, Big Potential
Challenge the confines of the MasterBox Lite 3 by utilizing its flexibility to free up space for larger components.
  • 3.5" Drive Bays 1
  • Color(s) Black
  • Series MasterBox Series
  • 2.5" Drive Bays 1
  • Legacy Cases
  • 5.25" Drive Bays 1
  • Dust Filters Front (MCW-L3S2-KW5N, MCW-L3S2-KN5N)
  • Dust Filters None (MCW-L3B2-KN5N)
  • Expansion Slots 4
  • Radiator Support - Front Up to 240mm
  • Net Weight 3.65 Kg
  • Cooling System - Rear 1x 120mm fan (optional)
  • Power Supply Support Upper Rear Mount
  • Maximum Compatibility - CPU Cooler Height 157mm (Maximum)
  • Cooling System - Front 2x 120mm fan
  • I/O Panel 2x USB 3.0 (KW5N/KN5N)
  • I/O Panel 1x USB 3.0, 1x USB 2.0 (KN5N)
  • Maximum Compatibility - VGA Card Length 345mm (Maximum)
  • Dimensions (L x W x H) 406 (L) x 180 (W) x 379 (H) mm
  • Model Number MCW-L3B2-KN5N
  • Model Number MCW-L3S2-KN5N
  • Model Number MCW-L3S2-KW5N
