MasterBox K501L & K501L RGB Mid Tower PC Case image number 0
MasterBox K501L & K501L RGB Mid Tower PC Case image number 1
MasterBox K501L & K501L RGB Mid Tower PC Case image number 2
MasterBox K501L & K501L RGB Mid Tower PC Case image number 3
MasterBox K501L & K501L RGB Mid Tower PC Case image number 4
MasterBox K501L & K501L RGB Mid Tower PC Case image number 5
MasterBox K501L & K501L RGB Mid Tower PC Case image number 6
MasterBox K501L & K501L RGB Mid Tower PC Case image number 7
MasterBox K501L & K501L RGB Mid Tower PC Case image number 8
MasterBox K501L & K501L RGB Mid Tower PC Case image number 9
MasterBox K501L & K501L RGB Mid Tower PC Case image number 10
MasterBox K501L & K501L RGB Mid Tower PC Case image number 11
MasterBox K501L & K501L RGB Mid Tower PC Case image number 12
MasterBox K501L & K501L RGB Mid Tower PC Case image number 13
MasterBox K501L & K501L RGB Mid Tower PC Case image number 14
MasterBox K501L & K501L RGB Mid Tower PC Case image number 15
MasterBox K501L & K501L RGB Mid Tower PC Case image number 16
MasterBox K501L & K501L RGB Mid Tower PC Case image number 17
MasterBox K501L & K501L RGB Mid Tower PC Case image number 18
Your Angle of Attack
Gaming is in the core of the new MasterBox K501L. Donning an illuminated fan against the angled front panel ventilation speaks to its competitive...
  • Materials Steel
  • Dust Filters Top
  • Dust Filters Front
  • 5.25" Drive Bays 0
  • Materials Plastic
  • Color(s) Black
  • Series MasterBox Series
  • Size Mid Tower
  • Clearance - PSU 180mm/7.08"
  • Dust Filters Bottom
  • Motherboard Support SSI CEB
  • Power Supply Support ATX
  • Volume 40.3L (exlc. Protrusions)
  • Fan Support - Rear 1x 120mm
  • Motherboard Support E-ATX*
  • I/O Panel 1x USB 2.0
  • Expansion Slots 7
  • Motherboard Support ATX
  • Fan Support - Bottom N/A
  • Cable Routing 19mm/0.74"
  • Materials Mesh
  • Fan Support - Top 2x 140mm
  • I/O Panel 1x USB 3.0 Type-A
  • Fan Support - Top 3x 120mm
  • Motherboard Support (*support for up to 12" x 10.7", will limit cable management features)
  • Weight 4.9 kg
  • Clearance - PSU 295mm/11.61" (w/ HDD cage removed)
  • Clearance - GFX 410mm/16.1"
  • Weight 6.3 kg
  • I/O Panel 1x 3.5mm Mic Jack
  • Pre-installed Fans - Front 1x 120mm Red LED (MCB-K501L-KANN-S00)
  • Pre-installed Fans - Front 1x 120mm RGB LED (MCB-K501L-KGNN-SR1)
  • Materials Acrylic (MCB-K501L-KANN-S00)
  • 2.5" Drive Bays 4 (2+2 combo)
  • Materials Tempered Glass (MCB-K501L-KGNN-SR1)
  • Dimensions (L x W x H) 496mm x 217mm x 469mm (incl. Protrusions)
  • Dimensions (L x W x H) 428.7mm x 205mm x 458.5mm (excl. Protrusions)
  • Model Number MCB-K501L-KGNN-SR1 (MasterBox K501L RGB)
  • Model Number MCB-K501L-KANN-S00 (MasterBox K501L)
