MasterBox K500L image number 0
MasterBox K500L image number 1
MasterBox K500L image number 2
MasterBox K500L image number 3
MasterBox K500L image number 4
MasterBox K500L image number 5
MasterBox K500L image number 6
MasterBox K500L image number 7
MasterBox K500L image number 8
MasterBox K500L
MasterBox K500L
MasterBox K500L
MasterBox K500L
MasterBox K500L
MasterBox K500L
MasterBox K500L
MasterBox K500L
MasterBox K500L
SAVOR THE VIEW
MasterBox K500L
MasterBox K500L
  • Dust Filters Top
  • Left Side Panel Steel
  • Left Side Panel Acrylic
  • Dust Filters Front
  • 3.5" Drive Bays 2
  • I/O Panel 2x USB 3.0
  • Color(s) Black
  • Series MasterBox Series
  • Materials Plastic
  • Legacy Cases
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Fan Support - Rear 1x 120mm
  • Clearance - PSU 180mm/7.1"
  • Expansion Slots 7
  • Motherboard Support ATX
  • Drive Bays - 2.5" SSD 1 (Max. 6)
  • Clearance - CPU Cooler 163mm/6.41"
  • Fan Support - Top 2x 120mm
  • Cable Routing - Behind Motherboard Tray 15-23mm / 0.59-0.90"
  • Pre-installed Fans - Front 2x 120mm Red LED Fan
  • Clearance - GFX 400mm
  • Dimensions (L x W x H) 491 x 210 x 455mm
  • Dimensions (L x W x H) MCB-K500L-KNNN-S00 - 491 x 200 x 451mm
  • EAN Code MCB-K500L-KNNN-S00 - 4719512070147
  • UPC Code MCB-K500L-KNNN-S00 - 884102042652
  • UPC Code MCB-K500L-KANN-S00 - 884102043857
  • EAN Code MCB-K500L-KANN-S00 - 4719512071359
  • Model Number MCB-K500L-KANN-S00
  • Model Number MCB-K500L-KNNN-S00
