MasterBox K500 image number 0
MasterBox K500 image number 1
MasterBox K500 image number 2
MasterBox K500 image number 3
MasterBox K500 image number 4
MasterBox K500 image number 5
MasterBox K500 image number 6
MasterBox K500 image number 7
MasterBox K500
MasterBox K500
MasterBox K500
MasterBox K500
MasterBox K500
MasterBox K500
MasterBox K500
MasterBox K500
SAVOR THE VIEW
MasterBox K500
MasterBox K500
  • Materials Steel
  • Dust Filters Top
  • Dust Filters Front
  • 3.5" Drive Bays 2
  • I/O Panel 2x USB 3.0
  • Materials Plastic
  • Color(s) Black
  • Legacy Cases
  • Power Supply Support ATX
  • Materials Tempered Glass
  • Dust Filters Bottom
  • Fan Support - Rear 1x 120mm
  • Clearance - PSU 180mm/7.1"
  • Expansion Slots 7
  • Motherboard Support ATX
  • Clearance - CPU Cooler 163mm/6.41"
  • Drive Bays - 2.5" SSD 1 (Max. 6)
  • Pre-installed Fans - Front 2x 120mm RGB LED Fan
  • Fan Support - Top 2x 120mm
  • Cable Routing - Behind Motherboard Tray 15-23mm / 0.59-0.90"
  • Clearance - GFX 400mm
  • Dimensions (L x W x H) 491 x 210 x 455mm
  • EAN Code 4719512071120
  • UPC Code 884102043628
  • Model Number MCB-K500D-KGNN-S00
