MasterBox K500 ARGB Mid Tower PC Case image number 0
MasterBox K500 ARGB Mid Tower PC Case image number 1
MasterBox K500 ARGB Mid Tower PC Case image number 2
MasterBox K500 ARGB Mid Tower PC Case image number 3
MasterBox K500 ARGB Mid Tower PC Case image number 4
MasterBox K500 ARGB Mid Tower PC Case image number 5
MasterBox K500 ARGB Mid Tower PC Case image number 6
MasterBox K500 ARGB Mid Tower PC Case image number 7
Savor The View
The MasterBox K Series changed the PC case industry upon its launch. With an innovative mesh design that filters out dust, refracts light uniquely
  • Materials Steel
  • Dust Filters Top
  • 5.25" Drive Bays N/A
  • Legacy Cases
  • Dust Filters Front
  • Materials Plastic
  • Color(s) Black
  • Materials Tempered Glass
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Fan Support - Rear 1x 120mm
  • Motherboard Support ATX
  • Expansion Slots 7
  • Clearance - CPU Cooler 163mm/6.41"
  • Fan Support - Top 2x 120mm
  • Clearance - PSU 180mm
  • Clearance - GFX 400mm
  • 2.5" Drive Bays 1 (Max. 6)
  • Pre-installed Fans - Front 2x 120mm ARGB Fan
  • Weight 6.2 kg / 13.66 lbs
  • I/O Panel 1x 3.5mm Mic Jack
  • I/O Panel 1x ARGB Controller
  • I/O Panel 1x ARGB 2-to-3 splitter
  • Dimensions (L x W x H) 491 x 211 x 455 mm
  • UPC Code 884102043628
  • EAN Code 4719512095140
  • Model Number MCB-K500D-KGNN-S02
