MasterBox E501L Mid Tower PC Case image number 0
MasterBox E501L Mid Tower PC Case image number 1
MasterBox E501L Mid Tower PC Case image number 2
MasterBox E501L Mid Tower PC Case image number 3
MasterBox E501L Mid Tower PC Case image number 4
MasterBox E501L Mid Tower PC Case image number 5
MasterBox E501L Mid Tower PC Case image number 6
MasterBox E501L Mid Tower PC Case image number 7
MasterBox E501L Mid Tower PC Case image number 8
MasterBox E501L Mid Tower PC Case image number 9
Steadfast.
The MasterBox E501L is the essential solution for optimized cooling. A gradient of perforations below the ODD allow fresh air into the system
  • Materials Steel
  • Materials Plastic
  • Dust Filters Front
  • 3.5" Drive Bays 2
  • Color(s) Black
  • Series MasterBox Series
  • Size Mid Tower
  • 2.5" Drive Bays 2
  • Dust Filters Bottom
  • 5.25" Drive Bays 1
  • Cable Routing 19~27mm
  • Fan Support - Rear 1x 120mm
  • I/O Panel 1x USB 2.0
  • Expansion Slots 7
  • Motherboard Support ATX
  • Clearance - PSU 390mm (without radiator and HDD installed)
  • Clearance - PSU 200mm (with radiator and HDD installed)
  • I/O Panel 1x 3.5mm Mic Jack
  • Clearance - GFX 410mm (without radiator installed)
  • Clearance - GFX 360mm (with radiator installed)
  • I/O Panel 1x USB 3.2 Gen 1 (formerly USB 3.0)
  • UPC Code 884102063152
  • EAN Code 4719512090732
  • Dimensions (L x W x H) 481mm x 205mm x 458.5mm (incl. Protrusions)
  • Dimensions (L x W x H) 428.7mm x 205mm x 450.5mm (excl. Protrusions)
  • Model Number MCB-E501L-KN5N-S00
