MasterBox 520 image number 0
MasterBox 520 image number 1
MasterBox 520 image number 2
MasterBox 520 image number 3
MasterBox 520 image number 4
MasterBox 520 image number 5
MasterBox 520 image number 6
MasterBox 520 image number 7
MasterBox 520 image number 8
MasterBox 520 image number 9
MasterBox 520 image number 10
MasterBox 520 image number 11
MasterBox 520 image number 12
MasterBox 520 image number 13
MasterBox 520 image number 14
MasterBox 520 image number 15
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
MasterBox 520
Reaching New Brights
MasterBox 520
MasterBox 520 is the ideal chassis for satisfying the needs of both novice and experienced gamers.
Tempered Glass Front Panel
Three CF120 ARGB Fans Included
ARGB Controller Included
Removable Top Panel
Screwless & Tool-Free TG Side Panel
Removable HDD cage
  • Model Number MasterBox 520: MB520-KGNN-S01, MasterBox 520 White: MB520-WGNN-S01
  • Exterior Color Black, White
  • Materials - Exterior Steel, ABS Plastic, Tempered Glass
  • Dimensions (L x W x H) 499 x 210 x 498mm (Incl. Protrusions), 430 x 210 x 479mm (Body size)
  • Motherboard Support Mini-ITX, Micro-ATX, ATX, SSI-CEB, E-ATX* (*up to 12" x 10.7" motherboards, may impact cable management feature)
  • Expansion Slots 7
  • 3.5" Drive Bays 2
  • 2.5" Drive Bays 3
  • I/O Panel - USB Ports 1x USB 3.2 Gen 1 Type A, 1x USB 3.2 Gen 2 Type C
  • I/O Panel - Other 1x Reset/ARGB button
  • Included Accessories ARGB Fans Hub
  • Pre-installed Fans - Front 3x CF120 ARGB
  • Pre-installed Fans - Rear 1x MasterFan Lite 120
  • Fan Support - Top 3x 120mm, 2x 140mm
  • Fan Support - Front 3x 120mm, 2x 140mm
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Top 120 / 140 / 240 / 280 / 360mm (recommended maximum thickness - 55mm)
  • Radiator Support - Front 120 / 140 / 240 / 280 / 360mm
  • Clearance - CPU Cooler 165mm
  • Clearance - PSU 200mm (Recommended up to 170mm)
  • Clearance - GFX 410mm
  • Power Supply Support ATX
  • Size Mid Tower
  • Series MasterBox Series
