Screwless & Tool-Free TG Side Panel
The tempered glass side panel is secured with pins for easy removal, facilitating quick, easy installation.
Reaching New Brights
MasterBox 520 Mesh is the ideal chassis for satisfying the needs of both novice and experienced gamers.
Large mesh intakes offer unrestricted airflow and stellar thermals for demanding systems.
Choose the color that best matches your setup!
The top panel is entirely removable for improved access and easy installation of cooling solutions such as fans and radiators.
Pre-installed CF120 ARGB fans provide ample airflow, ensuring low temperatures, high performance, and eye-catching aesthetics during even the most intense gaming sessions.
Customization
Supports up to seven 120mm fans and dual 360mm radiators on the top 140mm and front panel.
MasterBox 520 Mesh is natively compatible with ITX, M-ATX and ATX motherboards.
E-AT motherboards, such as SSI-CEB models, are compatible with dimensions up to 12" x 10.7".
