MasterBox 500 image number 0
MasterBox 500 image number 1
MasterBox 500 image number 2
MasterBox 500 image number 3
MasterBox 500 image number 4
MasterBox 500 image number 5
MasterBox 500 image number 6
MasterBox 500 image number 7
MasterBox 500 image number 8
MasterBox 500
MasterBox 500
MasterBox 500
MasterBox 500
MasterBox 500
MasterBox 500
MasterBox 500
MasterBox 500
MasterBox 500
When Lightning strikes
MasterBox 500
With top-notch gaming support and stealthy, futuristic design, MasterBox 500 really is the best of both worlds.
  • Model Number MB500-KGNN-S00
  • Exterior Color Black
  • Materials - Exterior Steel, Mesh, Plastic
  • Dimensions (L x W x H) 505 x 209 x 499mm (incl. Protrusions), 491 x 209 x 499mm (excl. Protrusions)
  • Motherboard Support Mini-ITX, Micro-ATX, ATX, E-ATX* (*up to 12" x 10.7" motherboards, may impact cable management feature)
  • Expansion Slots 7
  • 5.25" Drive Bays N/A
  • 2.5" Drive Bays 4
  • I/O Panel - USB Ports 2x USB 3.2 Gen 1 Type A
  • I/O Panel - Other 1x Reset/ARGB button
  • ARGB Controller ARGB Hub
  • Pre-installed Fans - Front 1x 120mm CF120 ARGB
  • Pre-installed Fans - Rear 1x 120mm MF120 non-LED Fan
  • Fan Support - Top 3x 120mm / 2x 140mm
  • Fan Support - Front 3x 120mm / 2x 140mm
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Top 120 / 140 / 240 / 280 / 360mm (recommended maximum thickness - 55mm)
  • Radiator Support - Front 120 / 140 / 240 / 280 / 360mm
  • Clearance - PSU 180mm / 7.08" (295mm / 11.61" with HDD cage removed)
  • Clearance - GFX 410mm/16.1"
  • Power Supply Support ATX
  • Size Mid Tower
  • Series MasterBox Series
