You Decide the Inside
MasterBox 5 MSI Edition
Power Supply SupportBottom Mount
Liquid Cooling Support - Rear120mm
LegacyCases
2.5" / 3.5" Drive Bays (Combo)2
SeriesMasterBox Series
SizeMid Tower
I/O Panel2x USB 3.0
Liquid Cooling Support - Front240mm
Dust FiltersBottom
Power Supply SupportATX
Pre-installed Fans - Rear1x 120mm (Black)
Liquid Cooling Support - Front280mm
Fan Support - Rear1x 120mm
Clearance - PSU180mm/7.1"
Drive Bays - SSD1
Liquid Cooling Support - Front360mm
Fan Support - Front2x 140mm
Expansion Slots7
Motherboard SupportATX
Motherboard SupportMicro ATX
Fan Support - Front3x 120mm
MaterialsSteel body
Cable Routing - Behind Motherboard Tray25-35mm
MaterialsPlastic mesh bezel
Motherboard SupportMini ITX
Clearance - CPU Cooler167mm/6.5"
Color(s)Black & Red with MSI logo
Clearance - GFX410mm/16.1"
Dimensions (L x W x H)500 x 220 x 475 mm
I/O PanelAudio In & Out (Supports HD Audio)
EAN Code4719512058459
UPC Code884102031250
Model NumberMCX-B5S2-KWNN-03-MI
