MasterAir MA624 Stealth image number 0
MasterAir MA624 Stealth image number 1
MasterAir MA624 Stealth image number 2
MasterAir MA624 Stealth image number 3
MasterAir MA624 Stealth image number 4
MasterAir MA624 Stealth image number 5
MasterAir MA624 Stealth image number 6
MasterAir MA624 Stealth image number 7
MasterAir MA624 Stealth image number 8
MasterAir MA624 Stealth image number 9
MasterAir MA624 Stealth image number 10
MasterAir MA624 Stealth image number 11
MasterAir MA624 Stealth image number 12
MasterAir MA624 Stealth image number 13
MasterAir MA624 Stealth image number 14
Dual Tower Dual Fan Twice The Performance
Cooler Master’s MA624 Stealth brings to you twice the performance with dual fans and tower in a striking package.
  • Cooler Type Air Cooler
  • Exterior Color Black
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Fan MTTF 160,000 Hours
  • Series MasterAir
  • Warranty 5 years
  • Fan Quantity 140 mm Fan - 2 PCS
  • Fan Quantity 120 mm Fan - 1 PC
  • Heatpipes 6
  • CPU Socket LGA1700
  • CPU Socket LGA1366
  • CPU Socket LGA1200
  • Heat Sink Material 6 Heat Pipes
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • Note *LGA1700 mounting kit included in products with New Packaging Design. You may obtain required mounting kits for products with older package design through CM store or regional resellers and distributors.
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • Fan Power Consumption 1.8W
  • Fan Rated Current 0.15A
  • CPU Socket AM4
  • Fan Safety Current 140 mm Fan - 0.4A
  • Fan Safety Current 120 mm Fan - 0.37A
  • CPU Socket AM3+
  • CPU Socket AM3
  • CPU Socket AM2+
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Socket FM1
  • Fan Dimensions (L x W x H) 140 mm Fan - 140 x 140 x 25 mm / 5.5 x 5.5 x 1 inch
  • Fan Dimensions (L x W x H) 120 mm Fan - 120 x 120 x 25 mm / 4.7 x 4.7 x 1 inch
  • Fan Noise Level 140 mm Fan - 10 ~ 27 dBA
  • Fan Noise Level 120 mm Fan - 8 ~ 27 dBA
  • Dimensions (L x W x H) 144.9 x 153.2 x 160 mm / 5.7 x 6 x 6.3 inch
  • Fan Air Pressure 140mm Fan - 2.25 mmH2O (Max)
  • Fan Speed 140 mm Fan - 650-1400 RPM (PWM) ± 5%
  • Fan Speed 120 mm Fan - 650-1800 RPM (PWM) ± 5%
  • Fan Air Pressure 120mm Fan - 2.5 mmH2O (Max)
  • Fan Airflow 140mm Fan - 67 CFM (Max)
  • Fan Airflow 120mm Fan - 62 CFM (Max)
  • Product Number MAM-D6PS-314PK-R1
