MasterAir MA621P TR4 Edition image number 0
MasterAir MA621P TR4 Edition image number 1
MasterAir MA621P TR4 Edition image number 2
MasterAir MA621P TR4 Edition image number 3
MasterAir MA621P TR4 Edition image number 4
MasterAir MA621P TR4 Edition image number 5
MasterAir MA621P TR4 Edition image number 6
Supercharged Cooling Performance
The MasterAir MA621P TR4 Edition is built for extreme cooling performance that supports the ultimate platform for PC enthusiasts, AMD's TR4 socket.
  • LED Color RGB
  • Heat Pipe Dimensions Ø6mm
  • Fan Speed 600-1800 RPM ± 10%
  • Cooler Type Air Cooler
  • Heat Sink Dimensions (L x W x H) 116 x 110.1 x 165 mm / 4.6 x 4.3 x 6.5 inch
  • Fan Air Pressure 1.65 mmH2O ± 10%
  • Fan MTTF 160,000 Hours
  • Series MasterAir
  • Fan Safety Current 0.37A
  • Heat Sink Weight 870g / 1.91lb
  • Heatpipes 6
  • Product Number MAP-D6PN-218PC-R2
  • Dimensions (L x W x H) 121.8 x 136.1 x 164.5 mm / 4.8 x 5.4 x 6.5 inch
  • Heat Sink Material 6 Heat Pipes
  • CPU Socket TR4
  • Heat Sink Material CDC 2.0
  • Fan Power Consumption 3.6W
  • Fan Rated Current 0.30A
  • Fan Airflow 53.4 CFM ± 10%
  • Fan Noise Level 31 dBA (Max)
