MasterAir MA410P image number 0
MasterAir MA410P image number 1
MasterAir MA410P image number 2
MasterAir MA410P image number 3
MasterAir MA410P image number 4
MasterAir MA410P
MasterAir MA410P
MasterAir MA410P
MasterAir MA410P
MasterAir MA410P
MasterAir MA410P
The MasterAir MA410P is the upgraded version of the MasterAir Pro 4, the Pro standard in CPU air cooling design and production from Cooler Master.
  • Heat Pipe Dimensions Ø6mm
  • Cooler Type Air Cooler
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Fan MTTF 160,000 Hours
  • Series MasterAir
  • Heatpipes 4
  • Fan Safety Current 0.37A
  • Fan Speed 650-2000 RPM (PWM) ± 10%
  • Fan Air Pressure 2.34 mmH2O (Max)
  • CPU Socket LGA1366
  • Heat Sink Weight 420g / 0.93lb
  • Dimensions (L x W x H) 84 x 129 x 158.5 mm / 3.3 x 5.1 x 6.2 inch
  • CPU Socket LGA1200
  • Product Number MAP-T4PN-220PC-R1
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • Heat Sink Material 4 Heat Pipes
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • CPU Socket AM4
  • CPU Socket AM3+
  • Heat Sink Material CDC 2.0
  • CPU Socket AM3
  • CPU Socket AM2+
  • Heat Sink Dimensions (L x W x H) 60 x 116 x 158.5 mm / 2.4 x 4.6 x 6.2 inch
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Socket FM1
  • Fan Power Consumption 3.36W
  • Fan Rated Current 0.28A
  • Fan Airflow 66.7 CFM (Max)
