MasterAir G200P image number 0
MasterAir G200P image number 1
MasterAir G200P image number 2
MasterAir G200P image number 3
MasterAir G200P image number 4
MasterAir G200P image number 5
MasterAir G200P image number 6
MasterAir G200P
MasterAir G200P
MasterAir G200P
MasterAir G200P
MasterAir G200P
MasterAir G200P
MasterAir G200P
Low-profile 2 Heat Pipe Cooler With RGB Fan
MasterAir G200P
The MasterAir G200P is a 39.4 mm low-profile CPU cooler designed for small form factor cases and compact PC builds
  • Cooler Type Air Cooler
  • Fan MTTF 40,000 Hours
  • Static Pressure 2.4 mm H2O (Max)
  • Heatpipes 2
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Series MasterAir
  • LED Color RGB
  • CPU Socket LGA1200
  • Fan Rated Current 0.12A
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • Fan Power Consumption 1.44W
  • Fan Safety Current 0.15A
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • Heat Sink Material 2 Heat Pipes
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • CPU Socket AM2+
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Socket FM1
  • Heat Sink Material Copper Plate
  • Fan Dimensions (L x W x H) 92 x 92 x 15.4 mm / 3.6 x 3.6 x 0.6 inch
  • Fan Noise Level 6 - 28 dBA
  • Dimensions (L x W x H) 95 x 92 x 39.4 mm / 3.7 x 3.6 x 1.6 inch
  • Fan Speed 800-2600 RPM (PWM) ± 10%
  • Fan Airflow 35.5 CFM (Max)
  • Product Number MAP-G2PN-126PC-R1
